Poor acceration
Old Aug 30, 1999 | 01:20 PM
Doop
Guest
Posts: n/a
Poor acceration
My 76 F-100 (360 2BBL) has intermitent problems. When I accerlate from a dead stop sometimes it lags or dies unless I pump the pedal lighty several times. The vacuum advance and timing is good. Does this sound like the power valve or accerator pump is bad? Also, can this be replaced without rebuilding the carb?
Old Aug 30, 1999 | 10:17 PM
390fe's Avatar
390fe
Poor acceration
Sound to me like a bad accelerator pump to me. Yes it can be fixed without even removing the carb, if you have a Ford 2bbl carb. To check it, remove the air cleaner, and with the engine off, look down into the carb and open the primarys. You should see a steady stream of gas darn near as soon as you start to open up the throttle. If you don't see gas, or it's late, you need a new accelerator pump. It should take about ten minutes to change it.
Old Aug 31, 1999 | 05:54 PM
Carl......
Guest
Posts: n/a
Poor acceration
Jammin1
6.7L Power Stroke Diesel
Sep 20, 2021 07:40 PM
Jammin1
6.4L Power Stroke Diesel
Apr 5, 2012 01:12 PM
Gmcbuffalo
Nov 3, 2009 05:12 PM
Gmcbuffalo
Aug 26, 2009 07:08 AM
AstroturfHead
1997 - 2003 F150
Dec 8, 2002 09:55 PM
