03 STC fitting
Old Jan 30, 2010 | 02:38 PM
jagski2's Avatar
jagski2
03 STC fitting
I have my 03 taken apart for an egr block off and oil cooler kit. Picked up a stc kit from the dealer today. Fellow was not the normal guy being Saturday and I ended up with an 05 kit. Took the hpop cover off and saw that will not work. My question, is there a kit for 03 and should I even screw with it? Looking at the posts, to 05 kit looks easy, I could not imagine what the 03 kit would be, doesn't look that simple. Thanks, Jim
Old Jan 30, 2010 | 04:01 PM
ciscofreak's Avatar
ciscofreak
Jim, the 03 doesn't have a STC fitting to worry about. Only the 05+. If you're having high pressure oil issues, maybe someone familiar with the 03-04 hpop issues will chime in.
Old Jan 30, 2010 | 04:27 PM
jagski2's Avatar
jagski2
I'm not having a problem, but I have read there is issues with the fitting, so since I was in there, I would update. I take back the parts guy comment.. Thanks for the reply, I'll sleep well.
cheezit's Avatar
cheezit
ya the o3/o4 is different. I would think about replacing the pipe at the same time. if fit is good and no wear can be seen at the snap ring they all is good.
Old Jan 30, 2010 | 04:37 PM
jagski2's Avatar
jagski2
I checked for anything out of sorts, but everything looked good. I sure am glad I didn't have to mess with that pump, Thanks again, Jim
