1978 - 1996 Big Bronco
wheel spacers
Old Jan 30, 2010 | 02:24 PM
deadeyedevon's Avatar
deadeyedevon
wheel spacers
i was thinking about picking some up to widen the base, thought it could add a little handleing and just make it look cooler? any opinions
Old Jan 30, 2010 | 02:37 PM
kenpobuck's Avatar
kenpobuck
Personally i never cared for them much.It seems that they put more leverage on the axle/front spindle. Besides they used to really crack donw on us for haveing our tires out past the fenders, seems that they have relaxed on this lately tho.
Old Jan 30, 2010 | 02:57 PM
greystreak92's Avatar
greystreak92
They also increase pressure on the wheel studs making them more susceptible to shearing. Best to measure anyway because if you widen the footprint without measuring, you are asking to create rub on front bumpers and outer fenders.
Personally, if you want to widen the truck's footprint, swap wheels for a set with shallower backspacing. Again, you should measure for clearance first.
Old Jan 31, 2010 | 08:08 AM
helirich's Avatar
helirich
They do increase leverage on components. But it is no differnt then wider wheels assuming you have the same back spacing. Stud failure is not really an issue if their tight.
As far as scraping goes, you will decrease your turning circle because you dont hit the radius arms. (assuming you reset the stops) Of course you might have to cut fenders/bumper.
As far as handling goes, the wider stance on the back is definatly better. But the wider stance on the front actually moves the center of the tire out from the center of pivot. This causes a kind of bump steer. When you hit a bump on one side of the truck, it tries to drag that tire back. Steering stabilizers help in this reguard.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
