Sponsored by: Real Truck
Fuse for lighter?
Old Oct 13, 2004 | 03:24 PM
Turfscape LLC's Avatar
Turfscape LLC
Fuse for lighter?
Which fuse is for the lighter?
Old Oct 13, 2004 | 03:48 PM
wlihntr's Avatar
wlihntr
what truck do you have?
Old Oct 13, 2004 | 03:56 PM
RealMenPowerstroke!'s Avatar
RealMenPowerstroke!
Ummm... the one that's blown?? No, I'm just messing with ya.. Anywho, the SD's have a fuse diagram on the back of the panel, and I'm assuming the F150's should be the same. Otherwise there is a fuse diagram in the owners manual. Or if you have a multi-meter you can find it in about two minutes.
Best of Luck,
Corey
Old Oct 13, 2004 | 04:04 PM
Turfscape LLC
Yeah, sorry, it is a 99 F350SD. No diagram on the panel
Old Oct 13, 2004 | 04:07 PM
n578md's Avatar
n578md
It's fuse # 3 (20Amp) on a 1999 F350. It's used to power the cigarette lighter and the OBDII port.
Old Oct 13, 2004 | 04:08 PM
RealMenPowerstroke!
Huh, well that's odd... Course I speak from experience with 02 7.3 diesel, and 03 6.0 diesel. Did you check out your owners manual?? Also is it a 7.3 or a gasser? That would make huge difference in explaining the fuse placement...
Corey
Old Oct 13, 2004 | 04:12 PM
Turfscape LLC
It is the 5.4. I am trying to add a 2plug outlet in addition to the lighter. I spliced in to the blue power wire and then grounded the 2 plug add on to the steel cross member behind the cup holder. I left the ground for the lighter intact. Now neither work. I would like to check the fuse and also pull it to re-do the connections. Thanks for the help!
Old Oct 13, 2004 | 05:02 PM
wlihntr's Avatar
wlihntr
whoops double post....how did that happen, wierd
Old Oct 13, 2004 | 06:21 PM
Turfscape LLC
Thanks, guys. Fuse #3 and now I have 2 extra power points!
royh55
Electrical Systems/Wiring
Dec 25, 2009 07:19 AM
mh5500
Sep 25, 2009 12:27 PM
BigRalph2000
Jan 27, 2007 07:40 AM
Boltgunner
May 23, 2004 04:53 PM
