Swapping Transmissions - what's needed?
Old Sep 3, 1999 | 08:02 PM
Eric Payne
Guest
Posts: n/a
I have a 77 F100 2wd with a 3speed column shifted manual. I would like to swap up to a C4. What parts do I need for the swap besides the C4 a torque converter, and a transmission linkage. I think I heard somewhere that I would need a new steering column.
Also, how much does a good, remanufactured C4 cost?
Thanks
Eric Payne
Old Sep 4, 1999 | 07:00 PM
StockMan's Avatar
StockMan
On top of what you mention, you will need to change your column and swap the manual pedal assembly for an auto version. The easiest way to perform this swap is to buy a donor truck which has all the items you need. It will be more costly otherwise and less convenient. Make sure you get one with a good trans.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Sep 4, 1999 | 09:24 PM
jowilker's Avatar
jowilker
Good Post Stockie My man, I might suggest that the donor have the same engine as in his truck, so kick down connectors and carbs be like the ones needed.
John
Old Sep 5, 1999 | 05:02 AM
Deen Hylton
Guest
Posts: n/a
Don't forget the radiator with cooling lines for an auto (or at least an aftermarket cooler), a shifter for an automatic, and this I'm not sure on in your application but possible driveline yoke swaps or driveline modifications. Ah yes, will also need a flywheel for an automatic and don't forget to wire in a "neutral start safety switch".
Old Sep 5, 1999 | 06:23 AM
jowilker's Avatar
jowilker
Here, Here, Good shot man. Thats the reason that I say, BUY A DONOR, There are too many things to try to remember to get and could cause too many trips. Don't forget the pilot bearing must be removed.
FYI: The straight has a fly wheel, the auto is called a flexplate.
John
Old Sep 5, 1999 | 07:08 AM
1_Mike's Avatar
1_Mike
FTE Ken
40
Oct 27, 2016 11:11 AM
Rpayne
Jan 30, 2005 04:02 AM
troy payne
18
Jun 29, 2004 10:54 PM
shadowz
Sep 3, 2001 09:52 PM
Eric Payne
Sep 25, 1999 07:25 AM
