Rear heater control question.
Old Jan 29, 2010 | 08:16 PM
TYZ78F150's Avatar
TYZ78F150
My rear heater controls only work on the HI speed position no matter where I move the **** to. Could that be the switch, or something back at the blower itself? Anybody ever have this problem?
Old Jan 30, 2010 | 03:41 PM
cbradford's Avatar
cbradford
I'm thinking there is a voltage divider resistor that controls fan speed which would be in the rear blower box, not 100% sure but is a place to start. Maybe someone else will chime in.
Old Jan 30, 2010 | 05:00 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Not long ago there was a thread about it in here,same issue.
Dig a bit .
Old Jan 30, 2010 | 08:36 PM
TYZ78F150's Avatar
TYZ78F150
Dig a bit .
Will do. Thanks!
Old Jan 30, 2010 | 09:45 PM
ocrush's Avatar
ocrush
I went through the same thing a few months back, start with the resistor which is under the hood near the P/s wheelwell in the same housing as the blower motor. Its a little tricky to get to but its only two bolts. I had to end up replacing my blower motor as well due to the lower portion of it rotting out causing it to short out. My total cost was about 150.00 doing the work myself, and as of this date heat is working fine.
Old Jan 30, 2010 | 10:27 PM
NKENN's Avatar
NKENN
It appears as though the High Speed Auxiliary A/C Relay located in then left rear of the vehicle is stuck in the High Speed fan position. The contacts probably welded themselves in that position and the relay is no longer switching when power is removed from its coil. At least, that is the first thing I would check.
Old Jan 31, 2010 | 10:45 AM
TYZ78F150's Avatar
TYZ78F150
Left rear, as in the drivers side rear? Do I need to pull an access panel or something?
BMitch
Feb 27, 2015 06:43 AM
ianobetz
13
Feb 24, 2015 08:17 PM
MarauderV8
Dec 17, 2014 01:44 PM
vanman23
Jul 11, 2014 03:27 PM
Dj300ford
16
Oct 5, 2013 09:35 PM
