351HO intake
Old Jan 29, 2010 | 07:07 PM
bigblueovalman's Avatar
bigblueovalman
351HO intake
I'm wondering if you guys can tell me if a 351 Performer intake would be any better than the stock 351HO iron manifold. For the 300 plus bucks, would it be worth it? Going to freshen up my 86 351HO engine with a set of E7TE heads and some Hooker long tube headers. No hot rod,just want a little more torque. I have a new 600 Holley also. I heard on some other forum that the 302HO manifold was the same design as the Performer 302 and there was very little difference in performance.
Thanks for your responces--------- Bud in AZ
Old Jan 29, 2010 | 07:10 PM
bghnkinf250's Avatar
bghnkinf250
$300 is a little steep, for that money, why not step up a little more to the RPM?
Old Jan 29, 2010 | 07:11 PM
bghnkinf250
What about stepping up to tri Y headers if you do not spend the money on the intake? Those helped my torque.
Old Jan 29, 2010 | 08:31 PM
XLnAK's Avatar
XLnAK
Build or modify with a specific power band in mind. The aluminum intake you mention (performer) has served me well for over 13 yrs in a 1ton crew 4x. Aside from the duraspark II my rig is all pre emissions though. My tri Y headers made out to be a great addition to a lowend power producing combo.
As far as the very little performance difference that may be noted goes, Keep in mind that the whole package has to work together when completed. The stock pieces that you mention are all great solutions. The iron you mention can be port matched to the heads and extrude honed for great performance gains with all the stock type bolt placements and required emission related accommodations. Polished, light , aluminum wins in many respects every time though.
The mods you mention seem a bit hot rodish at any rate. A thumper cam and higher compression is all thats missing from the menu. The new heads will wake it up a bunch. A new cam while your in there would too.
I don't mean to antagonize, really. Best wishes
TheJunkMan
Engine Swaps
20
Jan 4, 2011 11:29 AM
uhhuhwhut
Nov 6, 2010 09:13 AM
muddyford911
17
May 29, 2009 12:39 AM
prodigy
Jul 31, 2002 07:40 PM
trucklover
Nov 12, 2001 12:51 PM
