Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Louisville
Old Feb 7, 2010 | 04:06 PM
Vinford's Avatar
Vinford
Ive tried everything and i cant get this thing turning over fast enough.
I charged both batterys all night.
I used a big battery charger with boost on it.
I plugged in the block heater .
Someone told me to check for a decompresssion lever?
Old Feb 7, 2010 | 05:04 PM
rbaker6336's Avatar
rbaker6336
no decompression on a detroit
you may have to take the starter apart and clean it some
could have a stuck brush or a rusted brush spring
Old Feb 7, 2010 | 05:31 PM
Vinford's Avatar
Vinford
This is how things are hooked up.
Where should i put my booster cables?
The red lines are battery cables.
The batterys are diffrent.
Old Feb 7, 2010 | 11:59 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Get your voltmeter, and measure the voltage on one of the batteries, then measure the voltage on the other battery. That will tell you what you have. If what you are showing us isn't skipping anything between the two batteries, then I suspect you have two 6 volt batteries hooked up in series.
If it is, you might have a deep cycle battery in there, (the larger one) and those really have no place in a truck that size anyway. They're more of a marine application.
Check the battery and starter cable connections. Clean any corrosion off. Clean all the ground connections. Get new batteries, like I posted before, and it'll spin over like there's no compression.
Old Feb 8, 2010 | 12:09 AM
Vinford's Avatar
Vinford
The big batterys like a Cat or a big machine battery.
The other ones just a normal pickup battery but its big.
Can you tell from my diagram where to hook up a boost.
I got a big charger with "Boost" and I dont think Im hooking it up right because it doesnt make and diffrence.
Old Feb 8, 2010 | 12:10 AM
Vinford's Avatar
Vinford
Originally Posted by rbaker6336
S/P switch =series/parallel switch which you shoundn't have
42 MT is series/size of starter which you should already have
Check for tags on alternator and starter they should both be 12V
No tag to be seen on alternator or starter.
Old Feb 8, 2010 | 12:12 AM
bigrigfixer
The Pacifier
How to hook up the charger will depend on the voltage.
Old Feb 8, 2010 | 12:41 AM
Vinford's Avatar
Vinford
Gotcha.................I think.
Old Feb 8, 2010 | 02:34 PM
merlynr's Avatar
merlynr
Your drawing shows series. If 12volt batteries, then you are getting 24volts across both batteries. Parallel is like when u jump start a reg 12volt battery and hook pos to pos and neg to neg with result of 12v to other battery.
Old Feb 8, 2010 | 06:37 PM
rbaker6336's Avatar
rbaker6336
with normal chargers you will need two of them one for each battery
you are hooked up for 24 volt
you would hook up jumpers off of 12 to each battery + to +, - to -
By the post configuration I would say the big battery is a 4D possibly if it is 12 volt
Old Feb 8, 2010 | 07:48 PM
Vinford's Avatar
Vinford
Between everything ive learned here and every thing others Ive asked have told me it looks like I need to get a couple of new batterys.
I didnt want to spend $300 bucks until I checked this thing out a little bit , but it looks like im going to have too.
Thanks for the help
Old Feb 8, 2010 | 11:00 PM
bigrigfixer
The Pacifier
Did you at least get a volt meter on those batteries? That'll answer a few of your questions.
Old Feb 8, 2010 | 11:02 PM
  #28
Vinford's Avatar
Vinford
Believe it or not my volt meter takes a battery and it was dead......................
Old Feb 10, 2010 | 05:45 PM
  #29
Vinford's Avatar
Vinford
I borrowed another big battery.
I cleaned all the posts and hooked everything up.
Hit the starter button and she started right up.
It purrs , hardly any smoke or anything.
Im having air issues now the brakes donr seeem to want to air up.
But at least i can move it around now.
Old Feb 10, 2010 | 10:20 PM
  #30
bigrigfixer
The Pacifier
Check the drain *****. They might not be seated properly, or if they're the twist type, might not be closed.
There might be a leak in the compressor discharge line.
The governor might be bad. Or, you might need to put an unloader kit in the compressor.
Keep us updated.
