TRANNY SWAP
Old Jan 28, 2010 | 08:54 PM
fordpride's Avatar
fordpride
TRANNY SWAP
Alright guys i just got a wrecked 96 psd with a manuel trains that has 140.000 on the clock for free. Mine is a 97 with an auto i would love to have the manuel. what i'm i getting into and how bad is it to do
Old Jan 29, 2010 | 01:06 AM
SaintITC's Avatar
SaintITC
Since you got all the parts (hopefully they're not broken), it's probably a long weekend or two to swap out the mechanical parts. Someone else here will have to tell you if there are any differences in the engine electronics. Are both trucks 2wd or 4x4? You'd need to rebuild that 5spd and get a new rear housing cover to convert it from 2wd to 4x4 (or back).
What I'm really interested in are all the extra spare parts you're gonna list here for sale. (I need a gray dashpad)
Old Jan 29, 2010 | 11:33 AM
Welk49's Avatar
Welk49
Wont be too bad I would assume since you have the donor truck. I am interested too in any spare parts you might be selling. What are you going to do with your old AT?
Old Jan 29, 2010 | 01:32 PM
foxracing0934's Avatar
foxracing0934
From everything that i have read it isnt that bad of a job, as long as you have a donor truck to get all of the parts that you need from. I dont remember the whole parts list but your going to need all of the obvious parts to switch over and then also the PCM and a few wother smaller things IIRC. How bad was the truck wrecked and where are you located?
Old Jan 29, 2010 | 05:41 PM
fordpride's Avatar
fordpride
they are bath 2wd the truck was fliped the windows were busted and its been sitting for about 8 months and the dash is cracked in two spots / i'm keeping the ENG./the auto will be for sale it's new with less than 5k on it as of now also has a bully dog shift kit i've got 3k tide up in the trains/ the rest will be sold
Old Jan 29, 2010 | 05:43 PM
fordpride's Avatar
fordpride
the wreck one is single wheel F350
Old Jan 29, 2010 | 09:03 PM
Brown Falcon's Avatar
Brown Falcon
you can use the auto PCM with a manual tranny, just not the other way around. But since you have the manual PCM I'd swap it.
Everything else should swap over just fine. Have to cut holes for the shifter and what-not...
Old Jan 29, 2010 | 09:21 PM
charlie92/7.3l's Avatar
charlie92/7.3l
iwould like to go the other way i have a zf 5 and want to have a auto i would like to swap every thing with some one
Old Jan 29, 2010 | 09:26 PM
dougbrown's Avatar
dougbrown
Fordpride, Will you be parting the rest out? If so where are you? I may need the passenger side tail light!
Old Jan 29, 2010 | 09:42 PM
SaintITC's Avatar
SaintITC
Are you sure about cutting holes for the shifter? My 2wd truck has the 4x4 manual shifter hole in it, but with a blank cover plate screwed and glued under the carpet.
Old Jan 29, 2010 | 09:56 PM
fordpride's Avatar
fordpride
yes and i'm in Lousisiana
Old Jan 29, 2010 | 10:01 PM
dougbrown's Avatar
dougbrown
OOOO little far for me to drive. I'll pm if I need the light. Trying to glue mine back together.
Old Jan 29, 2010 | 10:09 PM
charlie92/7.3l
im in north louisiana above shreveport i have 2 standard trucks and one auto i would love to have a auto in the truck i drive
Old Jan 29, 2010 | 10:13 PM
fordpride's Avatar
fordpride
check this site out real cheap
89-96 Ford F150 Tail Lights KS Chrome (pair)
Old Jan 29, 2010 | 10:14 PM
fordpride's Avatar
fordpride
and yes i do have them
