TC ????????
Old Jan 28, 2010 | 08:19 PM
muddman77's Avatar
muddman77
TC ????????
I thought Ive read on here that if u are driving say 55mph and tap and hold the brake while still given it throttle ur RPM should jump up, cause ur tc would unlock. Is this rite?
Old Jan 28, 2010 | 08:24 PM
Izzy351's Avatar
Izzy351
Depends on the year and tuning/PCM version.
Old Jan 28, 2010 | 08:38 PM
muddman77's Avatar
muddman77
2001 edge evo
Old Jan 28, 2010 | 08:44 PM
Izzy351's Avatar
Izzy351
Have you tried it without the Edge? I don't remember the years that do or don't, but tuning will affect it no doubt.
Old Jan 28, 2010 | 08:55 PM
muddman77's Avatar
muddman77
I cant remember if I have or not Ill give it a shot in the AM
Old Jan 28, 2010 | 09:14 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Regardless of whether or not you're running an Edge Evolution, your torque converter strategy will not change. The Evo "builds" a program based off of your factory computer calibration as it DOES NOT replace the operating code with a different one like a 4-bank chip can.
If you have an 01, you likely have a PMT2 or PMT3 PCM code. The simple answer to your question would be that your torque converter clutch will not disengage when you tap the brake pedal at 55 MPH.
On edit:
Why would you want it to unlock anyway?
Old Jan 28, 2010 | 09:23 PM
Izzy351's Avatar
Izzy351
Thanks Cody -- forgot about that detail with the Edge...
Old Jan 28, 2010 | 10:27 PM
rbaker6336's Avatar
rbaker6336
It is a pain when the torq unlocks when you tap the brakes,mine also unlocks about 30 seconds when I let off the throttle
I been thinking of trying a PMT1 or PMT2 PCM
