Ultra Low Sulfer
Old Jan 28, 2010 | 01:36 PM
farmdad's Avatar
farmdad
Originally Posted by balderman
Does brand matter for the 2 cycle oil? any recommendations, Also what is the benefit> Motor protection?
I don't buy the cheapest but during the winter, the selection seems to have diminished. Need to stock up in the summer. Regular biodiesel that you get from the pump, not used veggie oil, works well but isn't always available. DK does have extra benefits but may cost more.
The lubrication that these products have replaces what is lost when using ULSD as compared to LSD. Diesel fuel is used as a lubricant in diesel fuel systems and any loss of lubrication long term can have a detrimental effect on parts.
Old Jan 28, 2010 | 01:48 PM
brian42's Avatar
brian42
Veteran: Navy
Power Service Diesel Kleen (grey bottle). 3oz for every 10gal of fuel (or maybe just a smidge more) since I bought it 2 1/2 years ago.
Old Jan 28, 2010 | 01:52 PM
CSIPSD's Avatar
CSIPSD
I add at every fill up Diesel to my tank, fill it up to the top and drive until it gets low. Seems to work great for all my diesel pickups!
Old Jan 28, 2010 | 01:54 PM
mndiesel's Avatar
mndiesel
Shaeffers winter and summer year round, 1/2 can each tank
Old Jan 28, 2010 | 01:57 PM
Jerry Edwards's Avatar
Jerry Edwards
Thanks for all the help.I'll have to try it!
Old Jan 28, 2010 | 02:44 PM
Talyn's Avatar
Talyn
Injectors are what you want to worry about with our 7.3's
The fuel is so hard on them. so the benifit is all the lubrication you'll get with the 2cycle over other things becides soy diesel.
Originally Posted by Izzy351
I prefer the DK because it adds cetane for a better burn as well as lubricity. 2-cycle won't do that. I trade off a little extra lubricity for a little better burn. Just something to keep in mind.
I use DK every now and then, but I dont get better results with startup.
here is the lubricity test results done a year or 2 ago (maybe longer)
You be the judge on what benifits you'll get.
Either way, you can still mix DK and 2cycle as well. Get the cetane boost, and the lubricity of 2cycle.
Think really of how good 2cycle does with harsh gasoline. the 2 cycle in the fuel has to lubricate all the really hard working parts in a 2cycle motor.
Now think of how much it would help a HEUI system actuating thousands of times an hour.
File Type: pdf
Old Jan 28, 2010 | 04:37 PM
big poppa's Avatar
big poppa
Originally Posted by Talyn
I generally suggest against bio due to the fact of how good it is at cleaning out your fuel system.
So all the sluddge from the diesel fuel oil will end up in your filter, and you'll have to do a few filter changes.
Ran regular ole diesel up to 56,000 then ran a 5% bio blend to the present(133,000) and no clogging of my filter, heard it does it but the fuel around here I noticed is pretty clean. If not DK my vote is for a 5% bio blend, really smoothed things up.
Old Jan 28, 2010 | 05:18 PM
aklim's Avatar
aklim
Originally Posted by Kajtek1
nothing
Me too. Not interested in spending more on a product than what it can save.
Old Jan 28, 2010 | 05:20 PM
aklim's Avatar
aklim
Did you notice any difference the way your truck ran or sounded when they switched fuel?
Seems that mileage dropped a tad. I think it is some of the aromatic stuff that is removed that takes some of the BTU out. Not totally sure
Old Jan 28, 2010 | 05:23 PM
aklim's Avatar
aklim
The Bosch test is a much better test than what Spicer put out. They were testing a fuel pump but I would think that if we extrapolated from that test, you MIGHT lose UP TO 10% wear with the regular diesel vs what the manufacturers want. So, basically, you might have to rebuild your injectors at 90% life if you used 460 HFFR score as a benchmark. If the injectors cost about 1200 to rebuild, that comes to roughly $120 you will save by bringing your score up with the snake oils. I think you are going to spend way more than $120 to save that $120. Is it worth it? Probably not.
Old Jan 28, 2010 | 06:29 PM
flatbeder's Avatar
flatbeder
I found a fuel station in PHX that has the regular old fashion diesel fuel. The truck feels like it has more smoother acceleration, and is getting a little better fuel mileage. Glad I stumbled across this thread b/c I was curious on what to do if anything about dealing with the ULSD in my older PSD? Very insightful thanks guys!
Old Jan 28, 2010 | 06:32 PM
Loadre's Avatar
Loadre
DieselKleen. Almost every tank since the switch...
Same here. I can personally notice a big difference between not using it.
  #28
flatbeder's Avatar
flatbeder
I did see a post in this thread about using green or red 2 stroke oil...Red diesel fuel smells completely different then green fuel. I could always tell a difference and i use to service heavy CAT machinery on jobsite. Just my $.02. If dot cant tell that they need to give up there position as fuel checker...
Old Jan 28, 2010 | 06:45 PM
  #29
Bowie's Avatar
Bowie
So 2 cycle oil will not hurt the engine at all? Is a quart per tank really needed. I have been using stanadyne because I got it for free but I am almost out and will have to buy something (if needed)
Old Jan 28, 2010 | 06:46 PM
  #30
Izzy351's Avatar
Izzy351
Mine were *a little* more than that (like x2). And I don't want to do the job again unless I absolutely have to. Add in my labor cost of $100/hr x ~6 hrs for the job. So a little better burn, plus a little better mileage, plus not having to do the job again anytime soon = a good deal for me...
