Unreal Gas Mileage
Unreal Gas Mileage
I have a 1974/75 Ford 250 Ranger XLT with a 390 Fe 4bbl and manual 4 on the floor. Everything stock including wheels and tire size. I live on a moderate hill and drive the truck as my daily driver to the firehall and back approx. 5 miles each way. I have two tanks but only use the rear one (19 gallons). I get around 100 miles (if that) and i am not pushing the pedal to the floor either. The engine revs are low and smooth, new oil, air filter etc. truck is well taken care of. Any ideas what i can do to improve the mileage? I mean 5.3 mpg on premium fuel 92 octane can't be right.
As always any suggestions/information is welcome.
cord
cord
on
Hoist a sail?
I don't think these trucks were designed with fuel-efficiency in mind...
My mileage went down after I lost another valve seat...
I would suggest maybe tuning the carb a bit leaner and tweak the timing a bit - this is where a vacuum gauge comes in handy... I did that on my Fury and it seemed to help a bit with mileage...
74/75 not sure if you have a egr valve, but I had a 77 F150 4X4 351 and went from about 14 mpg to 4 mpg over night. I managed a self service gas station and had told a guy that ran the tune up shop next door about it and he took it over to his shop and tested it. Came back over and said the egr was bad and replaced it and the truck went right back to 14 mpg.
I'll second that. If you live in a state where you can get away with taking your EGR valve off, do it! I took the egr valve off a 400 that was giving me problems, set the carb right on top of the manifold and bolted it up, and it improved my gas mileage and performance astronomically. It could always be something else with the motor or carb but the EGR would be a good place to start.
Everybody knows how much of a pain in the @ss it is to fix the emissions system on a truck that had the egr and vac lines and such hacked up by the previous owner.
My truck has a 19 gallon tank and get about 100 miles to a tank as well. I don't run it 100% dry but I usually get anywhere from 6.5 to 9 mpg. Thats a built 460 and I think thats quite good mileage, the 9 is anyway. Unless you actually caculate the miles I would consider no way to deterimine if its good or bad.
