Electronic Ignition conversion
Old Sep 21, 1999 | 11:10 PM
BigBrownTruck's Avatar
BigBrownTruck
I am doing a top end rebuild on a 390 in a 69 F100, and I'd like to convert to electronic ignition. I was asking at the auto parts store about using a MSD and was told that they had a kit from Crane that was cheaper and better. Anybody have any good or bad things to say about the Crane Cams electronic Ignition?
Old Sep 23, 1999 | 09:03 AM
Marty's Avatar
Marty
I was
>better.
I haven't had any experience with either of these, but alot of guys on this site use and like the MSD system.
But if the Crane is alot cheaper it would be worth it. Crane makes a good cam, I would think they would make a good dist too.
Did he say how it was better? If you want more info, ask if he knows of someone that has one that you could talk to.
Any electronic ign is a great improvement over points. I went with a Duraspark conversion on my '73 390, it came out of a '76.
Just my 2 cents worth.
Old Sep 23, 1999 | 09:39 AM
TomC's Avatar
TomC
I used a duraspark unit out of a '76 ford truck also. My advice on electronic ignition would be to use the Hall Effect (magnetic) trigger type ignition. Some of the aftermarket type units use a LED type of trigger that I feel has a higher failure rate due to engine heat. The Pertronic brand conversion would probably be ok, especially when used with an MSD or Jacobs system.
Hope this helps...
Ps the Duraspark was really easy to hookup, just added a wire from the starter solenoid to the box and grafted in the plugs and connections from a junkyard donor Ford.
Old Sep 23, 1999 | 12:28 PM
Phillip Guidry's Avatar
Phillip Guidry
Old Sep 23, 1999 | 05:44 PM
Kikker's Avatar
Kikker
I've recently installed Pertronix electronic igition in my 65 F100 240-6 and so far very pleased with it at $ 74.00
71dusterdan
Garage & Workshop
22
May 30, 2016 04:34 PM
Khauler
13
Jan 31, 2011 10:28 PM
73 ford guy
Jul 7, 2008 07:32 PM
pbear6969
28
Oct 22, 2006 11:52 AM
rebocardo
Jul 5, 2002 06:46 AM
