6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Check your fuel filter!
Old Jan 28, 2010 | 07:40 AM
Tom's Avatar
Tom
Well, I ordered my first set of fuel filters on Monday from www.dieselfiltersonline.com. I was very impressed to see them ship that same day and arrive here yesterday. I ordered the Racor filters specified for our trucks, as from what I hear they're the same filters as the Motorcraft ones and are a few dollars cheaper.
When I opened them up the first thing I noticed was this:
I think this is a real problem. This could let particles through that could damage my fuel system and I'm in the process of trying to get these filters exchanged.
Make sure you check your filters!!!
Old Jan 28, 2010 | 09:08 AM
69cj's Avatar
69cj
If I'm correct that looks like the O ring for the cap and I would say that is the top filter since there is no membrane on it. Correct me if I'm wrong.
Old Jan 28, 2010 | 01:56 PM
senix's Avatar
senix
looks like the top filter to me as well. Yes the o-rings are just in the package for both filters.
I get mine from Ed. Motorcraft ones.
Old Jan 28, 2010 | 02:24 PM
jwheatley20's Avatar
jwheatley20
I believe he is talking about what to me looks to be a tear in the filter right in the dead center of the pic.
Old Jan 28, 2010 | 02:36 PM
69cj's Avatar
69cj
Well Crazy001, which is it. A tear or the O ring??
Old Jan 28, 2010 | 04:52 PM
Tom's Avatar
Tom
The small tear is what I was posting about. The O-ring is for the cap, no problem there!
It is the top "secondary" filter. The primary is smaller with the membrane around it, which is quite a bit smaller.
Old Feb 4, 2010 | 12:08 AM
Machinator's Avatar
Machinator
Did any of you notice it takes a while to start the damn thing after you change the filter?
Old Feb 4, 2010 | 04:49 AM
ssharber's Avatar
ssharber
After changing both filters, you are required to cycle the fuel pump 6 times for 30 seconds each time to purge the air from the system. If that's not done then the system would be hard to start due to the air in the lines.
Old Feb 4, 2010 | 05:11 AM
senix's Avatar
senix
and if cycling the key doesn't seem to get it after several attempts you can depress the fuel shutoff switch and crank while holding, it may then start.
Old Feb 4, 2010 | 10:41 AM
Machinator's Avatar
Machinator
So just turning the key on for 30 sec intervals 6 times will cycle most of the air out? Thanks.
scott
Old Feb 4, 2010 | 11:41 AM
senix's Avatar
senix
that is the intent per owners manual.
Old Feb 4, 2010 | 12:17 PM
Tom's Avatar
Tom
Well I heard back from the online retailer and they are sending me replacement filters ASAP.
I'm not positive that the small tear went all the way through the material, but I can say that it makes me very uncomfortable using it on a truck with an $8K fuel system that could be buggered by improper filtration. Since opening the filter to get a closer look might mean difficulty returning it, I'm just gonna exchange them for my peace of mind.
The biggest reason I started this thread was to remind everyone who does their own maintenance to thoroughly look at your filters before you install them. Just like Toyota and their gas pedals, nobody's perfect!
Old Feb 4, 2010 | 01:11 PM
hunter08's Avatar
hunter08
I pedpress the air valve stem on the top right just left of the brake fluid bottle.It gets a little messy sometimes but makes it quick if the cycling doesn't work.My diesel guy showed me that trick.Works good just messy at times.Just hold it till fuel comes out.
Old Feb 4, 2010 | 02:55 PM
2x6 bulldog's Avatar
2x6 bulldog
For a couple dollars more I always buy the motorcraft brand. If there is a fuel warranty issue they might check what brand filters you are using. This is not the place to save a buck! And yes I buy my filters at Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Feb 4, 2010 | 04:50 PM
ssharber's Avatar
ssharber
In Tom's defense, the filters he bought are Racor made, as are the fuel filters Ford sells; no difference whatsoever. Just doesnt have the Ford associated with it. Racor makes the filters Ford sells, so no less quality. I'm glad Tom pointed this out, as I didnt even look at mine when I changed them and it goes to show how easy it could happen even with quality filters. And Machinator, youre welcome. Senix made a good point also, one I didnt even think about but knew of. A good friend of mine's grandfather actually came up with that fuel shutoff idea when he worked with Ford years and years ago as a diesel engineer.
