390 crank woes
Old Sep 22, 1999 | 06:02 PM
msmyth's Avatar
msmyth
390 crank woes
My 76 F250 4x4's 390 has spun a bearing. Should I pull the heads and pull the piston's to see if the rod (bearing end) is out-of-round, or is it safe to just replace the crank and bearings? I'm looking at $65.00 for a complete gasket set versus $20.00 for the pan & timing set gaskets.
The heads were reworked about 25,000 miles ago (previous owner).
Old Sep 22, 1999 | 09:45 PM
390fe's Avatar
390fe
390 crank woes
Along with rcank and bearing replecement, I'd go ahead and have the rod checked, just to be sure.
Old Sep 24, 1999 | 09:23 AM
deleontow's Avatar
deleontow
390 crank woes
If your bearing spun, rod or main? Your rod will be bad, replace the rod, recondition rods are not very expensive.If your main spun, Major problems, normally cheaper to replace the block.
Are you having the crank cut?
Advise
Dave
Old Sep 24, 1999 | 06:55 PM
Mulletwagon's Avatar
Mulletwagon
390 crank woes
Usually a spun rod bearing wipes out the crank and rod. Final branch on your decision tree may say "short block rebuild". If you are already going to pull the crank and heads we're only talking about a new set of rings (assuming bore is in spec). HTH
FL Panhandle
Old Sep 24, 1999 | 11:07 PM
Doug Moore
Guest
Posts: n/a
390 crank woes
bigred.102
Jan 27, 2013 08:30 PM
tbm3fan
Feb 21, 2009 08:13 PM
gungho351
Nov 23, 2007 09:57 PM
352 blue
Jan 11, 2005 09:32 PM
Charles-65F350
Mar 31, 2001 11:05 PM
