IDM next, need help.
Old Jan 28, 2010 | 12:34 AM
newportman's Avatar
newportman
I did the 10 k mod on my 96 PS today & next want to do the IDM mod. What is the resistor that I will need & does radio shack carry them? Thanks fellas.
Old Jan 28, 2010 | 12:37 AM
chicagodragon's Avatar
chicagodragon
I did that mod, also, with radio shack resistors. OHM them out to make sure they are exactly what you want. The % on the pack is the accuracy. You may need to put one or more in line.
Old Jan 28, 2010 | 12:39 AM
chicagodragon
almost forgot, search 140v IDM MOD w pics. the best wright up out there. by brown falcon, ithink.
Old Jan 28, 2010 | 12:54 AM
newportman's Avatar
newportman
What size/ohm, resistor do I need ?
Old Jan 28, 2010 | 12:57 AM
chicagodragon
look in your other post, i rambled on about it
Old Jan 28, 2010 | 01:06 AM
newportman's Avatar
newportman
I'm not good at electronics, do I need 140 ohm resistor ?
Old Jan 28, 2010 | 01:10 AM
chicagodragon
no. either 75 or 78k. look on your IDM and see waht volt it is, it on the sticker. i dont have a pic, but its either 100 110 or 120v. i think its the second set of numbers. look under the hood on the drivers side fender.
Old Jan 28, 2010 | 01:13 AM
chicagodragon
BTW. do you have any non stock mods on your truck? DP, intake etc...?
Old Jan 28, 2010 | 01:26 AM
newportman's Avatar
newportman
I have 3"dp, 6637 intake,fpr shim,str8 dual pipes no muff's or cats, php chip on the way. Sorry but I am still not clear on the resistor issue, if my IDM is a certain # I need what or how many resistors.
Old Jan 28, 2010 | 01:31 AM
chicagodragon
the 100 and 110v IDMs need (1) 75k resistor. 120v needs (1) 78k resistor. i had to stack because the resistors werent exact. thats what the% on the pack means.
Old Jan 28, 2010 | 01:39 AM
newportman's Avatar
newportman
Will check #'s later today. Really appreciate the help !!
Old Jan 28, 2010 | 01:41 AM
chicagodragon
no prob, lemmie know. search for that tread, its very helpful https://www.ford-trucks.com/forums/8...od-w-pics.html
Old Jan 28, 2010 | 12:04 PM
richdawg's Avatar
richdawg
I did a write up last year, you may find some of the info helpful if you look:
https://www.ford-trucks.com/forums/8...ht=IDM+MOD+140
Good Luck!!
Old Jan 28, 2010 | 02:52 PM
Brown Falcon's Avatar
Brown Falcon
Here's my IDM write-up with pics. Hope if helps.
https://www.ford-trucks.com/forums/8...ml#post7405113
Also, make sure you take the 10k off before you put your chip in. The chip controls that for you so you don't need the 10k. I have a PHP chip and I love it!
