Starting problem
Old Jan 27, 2010 | 07:28 PM
olderguy's Avatar
olderguy
Question Starting problem
94 F150 5L with 127K. Everything normal till yesterday morning and this morning. When I tried to start the engine it would catch or fire, but would not run. After several tries I decided to push the accelerator down a little. Still would not start. Started pumping the accelerator and it started. Did not smooth out for maybe 2 seconds and then run normal if I controlled the idle speed. Had to hold the idle speed up for a minute or two and then everything normal. Runs and starts good rest of the day. No CEL or other indication of problem. Only recent work to the engine was a new IAC about 11 mos. ago. Any thoughts or help appreciated. Lon. Outside temp was about 32 F
Old Jan 27, 2010 | 07:33 PM
DBGrif91's Avatar
DBGrif91
When's the last time you ran a fuel system treatment thru it? Could be injectors getting gummed up.
Old Jan 27, 2010 | 07:36 PM
subford's Avatar
subford
Sounds like it was flooded.
Any time you put the throttle to the floor (pumping) while cranking you turn off the injectors and put extra air into the engine for starting a flooded engine.
Old Jan 28, 2010 | 02:17 PM
olderguy's Avatar
olderguy
Thanks for your replies. Using injector cleaner now. Will report results.
Old Jan 28, 2010 | 02:53 PM
pete17c's Avatar
pete17c
not sure where you are, but if the injector cleaner doesn't help, try some dry gas ..
Old Jan 28, 2010 | 03:33 PM
subford's Avatar
subford
Also pull off the vacuum hose to the FPR (Fuel Pressure Regulator) and see if any fuel is in the hose or comes out of the nipple of the FPR when you turn the key off and on.
If it does you have a bad FPR.
It would not be an injector doing this unless it was stuck open and I do not think putting a cleaner in the fuel tank will help.
If you run it on straight injector cleaner without any fuel (gas) that may help one though.
Old Jan 28, 2010 | 07:29 PM
olderguy's Avatar
olderguy
Live in southwest Missouri near Springfield. We are to get 8 in. of snow tonight. Will check that FPR as soon as possible. Thanks for replies and help.
Old Apr 6, 2010 | 11:38 AM
olderguy's Avatar
olderguy
It was the IAC valve again. Had been 4 years when last replaced.
