Excessive Break Squeaking
Old Apr 5, 2010 | 06:38 PM
302flareside1992's Avatar
302flareside1992
I Replaced My breaks a couple weeks ago and since about a week ago they have been sqeaking or squealing constantly when i press the break. i have done the breaks on my truck two other times the exact same way with no problem and i cant figure out what the hell is wrong with them. any suggestion??
Old Apr 5, 2010 | 06:49 PM
George84's Avatar
George84
Different pads will have different characteristics, some will cause more or less squeaking, others will produce more or less dust or a different shade of dust. Did you go with an oem replacement or like a full ceramic, maybe a semi metallic blend? And did you clean up everything with brake clean when replacing the brakes? Oil on the pads or rotors will cause squealing too.
Old Apr 6, 2010 | 11:56 AM
302flareside1992
it is an OEM replacement pad. and everything was sprayed with break cleaner.
Old Apr 6, 2010 | 12:11 PM
Lazy K's Avatar
Lazy K
If not already fitted try anti-squeal shims between the caliper piston and the pad backing on both sides.
