Lack of power
Lack of power
I have a 1991 Ford F-150 with the 5.0 engine and it lacks power on take off. The engine idles fine but when I go to pull off it feels as if the truck is working hard but not moving as fast as the engine sounds like it should. Is this the sign of a restricted exhaust? I did notice the right side exhaust manifold appears to be cracked. I also wondered if the cracked manifold was a sign of exhaust restriction. The muffler is only 3 mos old.
How long has this been going on, and have you tried pulling any codes? My suspicion is that your cracked exhaust manifold is causing extra oxygen at the O2 sensor, setting a lean reading and causing your truck to run rich. A long term rich condition can cause a catalytic convertor to overheat, leading to failure. I'd replace that cracked manifold and see what results you get.
Outlaw56
13
04-28-2014 05:43 PM
caaront
04-17-2014 11:06 PM
thedieselkid
05-20-2013 09:27 AM
michbol
11-14-2011 01:25 PM
Canute
02-22-2004 06:38 PM
