Read before restricting EGR
Old Apr 17, 2014 | 12:47 AM
caaront's Avatar
caaront
My truck would buck and jerk at 40mph and above, I read the thread on making a restriction plate for the EGR valve.
Tried it and it worked to smooth out the bucking, but the bogging and lack of power stayed.
It turned out to be not enough fuel pressure.
Since the new fuel pump restored pressure and power I removed the restriction plate from the EGR valve and its now running great.
So be sure and troubleshoot everything, I found the plate to be a band aid.
Old Apr 17, 2014 | 04:24 AM
Truck Guy99's Avatar
Truck Guy99
I have no egr and I never experienced these problems
Old Apr 17, 2014 | 05:24 AM
dixie460's Avatar
dixie460
No, he's saying it went like:
Truck runs like crap --> install EGR restrictor > runs slightly better > install fuel pump > truck back to normal > remove unnecessary EGR restrictor.
So he's saying the EGR restrictor didn't do much and wasn't the fix, not that it was the problem to begin with.
I also have no EGR and run advanced timing, and my truck is fine too.
Old Apr 17, 2014 | 06:35 AM
j perdue's Avatar
j perdue
Gosh, was that worth a new thread? I would have added it to the fuel pump or hill climb(?) thread.
Old Apr 17, 2014 | 10:49 AM
ravens fan's Avatar
ravens fan
you guys with no EGR how do you eliminate them?
i restricted mine maybe a year ago and mine ran good but now i am experiencing very low fuel pressure causing my truck to run like crap. i was told the EGR is probably bad
i dont want to spend $50 unless i have to
any suggestions?
Old Apr 17, 2014 | 11:21 AM
Lead Head's Avatar
Lead Head
What does low fuel pressure have to do with the EGR?
Old Apr 17, 2014 | 11:27 AM
dixie460's Avatar
dixie460
any suggestions?
EGR has nothing to do with fuel pressure, they are completely separate systems.
If you have low fuel pressure then either your pump is failing, your regulator is blown out, fuel filter's plugged, strainer (in the tank) is full of junk, or you have a crossleak (if it's a dual-tank truck).
As far as how I ditched my EGR... easy, just disconnected the vacuum line from the valve. You'll get a Check Engine light if you do this. I pulled the bulb on mine... I know when something's wrong with it and I don't need that thing telling me "CHECK ENGINE" when I know it's actually a TRANSMISSION problem.
Old Apr 17, 2014 | 01:22 PM
ravens fan's Avatar
ravens fan
well i havent done a fuel pressure test yet but i did test the regulator by removing the vacuum line from it and this has fixed my bogging/cutting out. so i am told by removing the line it boosted fuel pressure and that mine was running lean before
so im not sure what part i need to replace (someone said on FTE bad EGR?) it runs ok now but is sucking fuel like nobody's business
Old Apr 17, 2014 | 02:11 PM
Truck Guy99
any suggestions?
On mine, we cut the egr tube about 6 inches from the part that connects to the engine and welded on a cop. For my headers, I ordered a plug from summit racing
Old Apr 17, 2014 | 09:08 PM
ravens fan's Avatar
ravens fan
thanks truckguy99 and dixie that sounds like what i did i think?
Old Apr 17, 2014 | 09:19 PM
blkF250HD's Avatar
blkF250HD
Moral of the story is that you NEED to properly DIAGNOSE the problem before throwing parts at it or trying band aids. Compare measurements to specifications and go from there.
Old Apr 17, 2014 | 11:06 PM
caaront's Avatar
caaront
Amen, and so glad I got it sorted out.
olfordsnstone
Aug 20, 2013 11:14 PM
Fulthrotl
May 5, 2013 01:15 AM
lengineering
Jan 30, 2008 10:51 AM
Steve390
17
Mar 12, 2003 03:12 PM
