Oil Recommendations / Capacity?
Old Feb 5, 2010 | 10:36 AM
PwerStroke99's Avatar
PwerStroke99
my vote is for Schaeffers 9000 5w40 full synthetic. my truck loves it
Old Feb 5, 2010 | 12:17 PM
RussB's Avatar
RussB
I ran the motorcraft stuff for 333,000 kms on my original motor ! Changed it every 5000kms (3000miles) and it seemed to do fine ! But that motor is gone now and I never had an oil analyses done on it ! The new motor is going to get shaffers that was just delivered to the house ! Its stupid expensive up here in canada, but I want to see what the difference is !
Old Feb 5, 2010 | 04:00 PM
white Buffalo's Avatar
white Buffalo
Which oil? The 9000 5W-40? 7000 15W-40?
I assume the 5W-40 since you're further up North.....
Old Feb 5, 2010 | 04:20 PM
PwerStroke99
Russ id recommend the 9000 5w40. i ran 7000 her ein Washington and didnt like it near as much as the 9000
Old Feb 5, 2010 | 04:58 PM
RussB's Avatar
RussB
I'm going to try the 7000 15w40 for now.. if it doesn't like that I'll go to the 9000. Thanks for the advise ! but I already bought the 7000 ! Ya its expensive up here !
Old Feb 6, 2010 | 09:18 AM
white Buffalo
Russ,
I don't know how hard it is for you to do this or if it is possible. But next time, can you ferry/drive across the border and get some since you live close to the border? Or will you have to change the oil in the States or something crazy like that?
Gonna get pretty busy in your neck of the woods shortly huh!
Old Feb 6, 2010 | 09:26 AM
white Buffalo
I run the series 7000 15W-40 here also in South Dakota. A bit stronger additive package and tends to shear less in higher ICP applications - has a nice dose of Antimony - high pressure additive. But I can understand Ken's (Powerstrk99) preference for better cold starts. We've been around the table on this discussion a couple of times in the past - nothing wrong with either choice.
Old Feb 6, 2010 | 11:05 AM
RussB's Avatar
RussB
Originally Posted by white Buffalo
Russ,
Yup getting busy up here already ! I would go to the states for it.. but to make a special trip just for oil isn't worth it when you add the $120 ferry ride to get off the island !
Old Feb 6, 2010 | 11:48 AM
white Buffalo
I didn't consider the $120 ferr ride......
Old Feb 6, 2010 | 01:32 PM
big poppa's Avatar
big poppa
Man Rich, you ain't kidding that 7000 is loaded with extra doses, definetly makes me feel warm and fuzzy inside, you know my story, and I'm very happy with the 7000. I had some shearing issues when I showed him my last UOA, 10,000 mile intervals down to 8000 now per Schaeffers lab and Rich.. Rotella 5-40 to 97,000 then the 9000 synthetic to about 132,000 now the 7000 syn blend, good stuff so far. On a very cold morning I might get a romp or two but it smooths right on out.
Old Feb 6, 2010 | 01:36 PM
Izzy351's Avatar
Izzy351
The only thing I see a big difference in is "Antimony". WTF is Antimony???
Old Feb 6, 2010 | 01:42 PM
bfife's Avatar
bfife
still plays with trucks
sounds like something my Exwife wanted! "shudder"
Barney
Old Feb 6, 2010 | 01:45 PM
  #28
big poppa's Avatar
big poppa
Barney
Sounds like it to me too, just different vanacular, double shudder...........
Old Feb 14, 2010 | 08:51 PM
  #29
jrciii56's Avatar
jrciii56
Rich are you sure that is not the oil CI-4 for the 7000? I am thinking that all CJ-4 oil has a max of 1200 ppm zinc.
Old Feb 15, 2010 | 08:27 AM
  #30
SGnAZ's Avatar
SGnAZ
Originally Posted by blkbest
Your right, it was 15w40 "Powerstroke Diesel" Motorcraft oil.
That's what I use,no problems.
