Modular V10 (6.8l)
engine noise when cold...
Old Jan 25, 2010 | 10:39 PM
fencer's Avatar
fencer
Before the engine reaches operating temp it makes a slight clattering noise at idle. After it warms up it goes basically totally away. What could this be? It runs fine, but does put out a cloud of blue smoke at start up occasionally. Any ideas? Thanks
Old Jan 25, 2010 | 11:45 PM
Fordfanatic4life's Avatar
Fordfanatic4life
check your exhaust manifolds. look at the studs/nuts to see if your missing any, or if some are loose..
without actualy hearing whats gongi on, its hard to say what it is.. but a exhaust leak when cold will usualy seal up when the engine gets hot if its not to big.
Old Jan 26, 2010 | 08:18 AM
fencer's Avatar
fencer
Its def not exhaust related. We got all the broke studs fixed. I tried running 10w-30, 5-30 and 5-20 in it, but it doesnt make much difference. The noise cannot be heard while driving but is really noticeable at cold idle. When teh truck was bought it did not have an air filter in at all. Also looking down the oil fill tube, you can see some sludge and build up... It has done this as long as we have owned it.
Old Jan 26, 2010 | 02:48 PM
TEAM HARD's Avatar
TEAM HARD
try a replacing a quart of your engine oil with a quart of Lucas oil?
how much oil are you using between changes?
Old Jan 26, 2010 | 04:31 PM
dkf's Avatar
dkf
May be piston slap. Year of truck and how many miles?
Old Jan 26, 2010 | 07:16 PM
fencer's Avatar
fencer
On this oil change with the Motorcraft 5-20, it is using a quart every 600-700 miles. It used about a qt to 1000 before on 5-30. It does smoke some sometimes when you start it but none at all when it is running.This poor old truck has really been through it. It didnt have a air filter when we bought it, but couldnt see much dirt in the intake so I dont think it had been out long. THey said it had just been serviced so maybe they just forgot to put one in when they changed it. Then I changed the sway bar bushings and put the sway bar on upside down and it hit the oil pan and cracked it. It was drove mabee 2-3 miles without any oil. I just noticed the guage was down but couldnt tell anything at all different with how it was running. Pulled the pan and fixed it and while it was off I looked at the cylinder walls and believe it or not they looked great! You could see the cross hatches really good and I couldnt see any grooves or scaring. It has always made this clatter at idle and it seems it has got just alittle louder over the 15000 mi we have put on it but not much.
Old Jan 26, 2010 | 07:18 PM
fencer's Avatar
fencer
2001 with 90000
Old Jan 26, 2010 | 08:19 PM
dkf's Avatar
dkf
What brand oil filter have you been using?
Using a quart of 5w-30 in 1k miles is excessive in my book but still within Fords acceptable range. If the valve seals are not in the greatest shape you can get a puff of smoke at startup. The modulars have also been known to produce a puff of smoke on startup sometimes if the truck is ran for a minute or two and shutoff, then the next time it start it you'll get a puff, but its fuel. I would try to replace the PCV valve to see if that helps you consumption. Running a full synthetic oil will help to remove any sludge in the engine but the engine will consume more synthetic than reg dino or blend. Sounds like that engine has shure been through a lot.
Old Jan 26, 2010 | 08:41 PM
fencer's Avatar
fencer
What does piston slap sound like? Or what is rod knock?
Old Jan 26, 2010 | 08:44 PM
fencer's Avatar
fencer
I have some Schaeffers 15-40. Would that be ok to run in it?
Old Jan 26, 2010 | 08:57 PM
fencer's Avatar
fencer
Oil filter is Motorcraft 820
Old Jan 27, 2010 | 08:17 AM
dkf's Avatar
dkf
You can find some vids of piston slap on youtube.
Old Jan 27, 2010 | 05:57 PM
fencer's Avatar
fencer
I ll check them out. Thanks alot...
Rick_Fury
45
Jun 1, 2011 07:03 AM
Rick_Fury
15
Feb 20, 2011 07:43 PM
seeker48
1983 - 2012 Ranger & B-Series
Jun 16, 2008 08:03 PM
davidson915
Jan 23, 2008 05:48 PM
andrewsmith
Oct 6, 2007 07:37 AM
