Sponsored by: Real Truck
Battery experience-Duralast Gold
Old Jan 25, 2010 | 12:39 PM
Vijay's Avatar
Vijay
Ok, I bought two new batteries for my dually in Sep of 2006 from Autozone, its Duralast –Gold yellow top. So, it’s been 3 years and 4 months so far. The warranty on these batteries was 3 years. Guess what, the batteries are not holding charge anymore. I parked my truck for 2 weeks and the battery is dead. I have parked this truck for over 3 weeks and it was starting just fine. Has anyone been through these batteries, I find it extremely discomforting that the warranty expires and so are the batteries. They are quite expensive to begin with. The factory batteries last 6 years!
Old Jan 25, 2010 | 01:21 PM
bpounds's Avatar
bpounds
I would not put Duralast in my truck, but some guys here have and think they are okay. So opinions are worth what you pay for them. But a couple of things come to mind. Did you get them load tested to see if it is actually one or both batteries that have failed? Second, 3 years was probably just the free replacement period and you should have prorated warranty beyond that. Of course that only helps if you buy the same thing again, and I'm guessing you won't. Nor would I.
For about $125 each you can get genuine Motorcraft again, or my preference which is Interstate.
Old Jan 25, 2010 | 02:05 PM
Vijay's Avatar
Vijay
I have not load tested either but since I have to replace both I figured it does not matter. I'm frustrated with cheap quality stuff they sell at Autozone. Costco batteries are half the price and CCA is better( 875), I think I will give them a try.
Old Jan 25, 2010 | 02:35 PM
bpounds's Avatar
bpounds
I guess my point on the load test is, you need to know if it is really a bad battery, and not a bad alternator or a transient current draw.
As far as Costco batteries, I think you will just be trading one cheap battery brand for another. Just my opinion of course.
Old Jan 25, 2010 | 02:58 PM
jlmotox's Avatar
jlmotox
I have them in my truck...so far so good. had them now for almost 1yr. Autozone has a great warranty! you should have discharged them and taken them back before your 3yr warranty was up, they would have given you brand new ones for free. take them back now anyways because they are prorated for 7-8yrs if I remember correctly.
Old Jan 25, 2010 | 04:07 PM
sdetweil's Avatar
sdetweil
I just had to replace one of the duralast batteries that I use on my trailer.. out of free replacement, but it only cost $11 for the prorated exchange on a $90 battery.. (and this is the second replacement.. first had a bad cell after 6 months, only time in 20 yrs of batteries that has happened)
So, I am happy
Sam
Old Jan 25, 2010 | 04:27 PM
bpounds's Avatar
bpounds
You guys make them sound really good!
Old Jan 25, 2010 | 07:00 PM
bohiaa's Avatar
bohiaa
NOTICE:
I purchased a walmart battery about 4 mts ago for my 93. it only lasted about 1 month.
returned it and sam thing. the manager said there was a problem at the factory,
where the postive post connects at is a defect, and they make several diffrent brands.
I went with motocraft. that's what's in my F250 and I got 9 years out of her.
Old Jan 25, 2010 | 08:53 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Almost all batteries are made by three manufacturers. I can't see there being much difference between different branded batteries made by the same manufacturer except for the name on the case. Below is a thread that discussed this subject. There's one post that indicates which batteries are made by which manufacturer.
https://www.ford-trucks.com/forums/9...tteries-2.html
Old Jan 26, 2010 | 09:20 AM
bpounds's Avatar
bpounds
I strongly disagree.
Almost all American cars are made by three manufacturers. Does that mean all Ford vehicles are the same?
Old Jan 26, 2010 | 09:25 AM
dkf's Avatar
dkf
Were talking a battery with plastic, lead and an acid/water mix here, not a vehicle with thousands of parts.
There are more specialty battery makers out there but for the most part there are only a handful of lead/acid battery companines in the US. I suspect the main reason the MC batteries tend to last in the new vehicles they are fresh when they are installed in the vehicles at the factory and the vehicle has a new charging system.
I've installed 5 Duralast batteries within the last 4 years in several vehicles and all are still running them. ( 1gold top, 1 blue top and 3 red tops) The blue top is the starting battery for the boat which sees the harshest use for a battery, it gets beat around in trailering and on the water, is stuck in a damp and dark abttery compartment and will sit for months on end hooked up and it still works fine. (In service for going on 4 years)
Old Jan 28, 2010 | 05:41 PM
kc2006's Avatar
kc2006
i've used duralast for along time, used them in race cars, a boat, and 2 trucks.
The last truck I had, I brought them back at the 3 year mark just to get new ones in it while they were free replacement. One battery that was in my one race car finally wouldnt hold a charge after 6 years, brought it back and it was something like 42 dollars on a 80+ battery.
Old Jan 28, 2010 | 07:22 PM
motown's Avatar
motown
I just put a Deka in my truck, they have a very good reputation. Napa has them making their Napa Premium batterys now.
Old Jan 28, 2010 | 07:32 PM
Surge08's Avatar
Surge08
I have 2 walmart yellow top batterys, no problem here. Walmart as of september 09 switched battery makers to exide
Old Jan 29, 2010 | 06:39 AM
bucci's Avatar
bucci
I'll never buy a Exide battery.
