1978 - 1996 Big Bronco
timing
Old Jan 30, 2010 | 11:12 AM
mprice's Avatar
mprice
Originally Posted by fordbroncodave
it will be hard breaking the news to some douchebag kid on youtube with his 3 step goal of getting 30+ out of his bronco.
Bahaha! I'd be happy to get that out of my Taurus. The stupid winter blend gas and short trips barely get me over 20!!
Old Jan 30, 2010 | 01:12 PM
greystreak92's Avatar
greystreak92
And for those who wanted to know what the SPOUT connector does and why it must be removed to set the base timing...
The SPOUT (SPark OUTput) connector takes the timing control signal away from the computer. This forces the spark timing to be exactly as it is set with the distributor position. Think of the SPOUT connector as the vacuum advance on an older carburated vehicle. In order to set the timing properly you had to keep the manifold pressure from affecting the timing advance triggered by the vacuum line to the distributor. The SPOUT connector does the same thing but electronically since spark timing is no longer controlled by vacuum but by the ICM (Ignition Control Module).
Attempting to set timing without removing the SPOUT connector (or vacuum advance line on an older vehicle) will yield incorrect timing and cause all kinds of performance problems including knock, loss of power, pre-ignition, and failed spark plugs.
Keep in mind too, that setting the timing with the engine at full operating temperature is critical. Otherwise the changes in fuel/air ratio will cause an incorrect base timing setting as well.
Old Feb 24, 2010 | 01:03 PM
'96 Bronco's Avatar
'96 Bronco
oh but havent you guys seen those chips on ebay that give you like 50 mpg and like 100hp boost? oh man I love those ads.
but yea the best I have ever had for mileage was 15 maybe 16 and that was a full tank on nothing but highway. ha
mrpotatohead
13
Feb 27, 2017 11:43 AM
jackietreehorn
19
Oct 16, 2016 06:01 PM
captanron
Jun 17, 2016 11:46 PM
aharleycpl
Dec 31, 2015 10:35 AM
reddogracing
Dec 10, 2015 06:44 PM
