Sponsored by: Real Truck
2003 sd 350 6.0 help
Old Jan 24, 2010 | 07:19 PM
mtclay1's Avatar
mtclay1
finally got the beast started by using block warmer, changed the egr valve and fuel filters. Runs okay, but engine light still on. I needed to use my battery charger on the 225 amp 12v start position to help get it started. Once started it will re start but needs a little throttle to do so.I need new batteries, does any one have a preference?the batteries i have are original(5yrs old now) and need to be replaced. when engine sits, i have to go through the same routine. How can i tell if the glow plug system is working? the light goes out quickly every time. Can the bad batteries(not very bad, engine seems to turn over fine) keep it from starting thanks clay
techno101
Jan 17, 2015 09:48 PM
JE917
Jul 10, 2010 07:27 PM
MOOOOOPS
Jun 8, 2010 01:23 PM
avator
1997 - 2003 F150
13
Dec 1, 2008 10:49 PM
