Is this blend door problem
temperature problmes are related to the blend door and the **** on the dash. pull lthe **** off and make sure it is not cracked where it grabs the steel shaft. since it changes temp without you moving the ****, it would appear to be more in teh blend door area. the door and motor drive and below the radio, above the transmission hump. take off the plastic cover and you can see part of it. move the **** and the electric motor should stroke the door with a plastic arm.
prellinger
07-27-2005 05:30 PM
