question
Old Jan 24, 2010 | 12:34 PM
victorminisan's Avatar
victorminisan
Question question
I have a 1985 ford f-150 that has a 351w, c6 tranny, 9" rear end with 4.11 gears. I was driving down the road and it was like you threw the tranny into neutral, i checked the fluid and the linkage, and the transfer case and no problem there. so i was wondering if there is a valve or something causing this, or if this has happened to annyone else before. anny feedback would be great, thanks
Old Jan 24, 2010 | 12:45 PM
bghnkinf250's Avatar
bghnkinf250
Did it go back into gear on its own?
Old Jan 24, 2010 | 12:47 PM
Franklin2's Avatar
Franklin2
Pull the tranny dipstick and look at the fluid. It should be pink(new fluid), or dark red(older fluid). If it's a light brown and stinks like it's burnt, you should pull the pan and change the fluid and the filter.
After you pull the pan, see how much junk is in the bottom of the pan. A fine metal dust in the bottom of the pan is normal. Large chunks are not normal, and you may need a rebuild.
Old Jan 24, 2010 | 01:00 PM
victorminisan
it wont go into anny gear, even after i manualy shifted it. and the fluid is good in color and level.
Old Jan 24, 2010 | 06:59 PM
dustybumpers's Avatar
dustybumpers
dumb question, but.... is the driveshaft still on it?
Old Jan 24, 2010 | 07:17 PM
ri_truck_guy's Avatar
ri_truck_guy
How did you check the transfer case? Have you tried shifting it? It could be a bad fork in there. Put it in low and then try to drive it.
Old Jan 24, 2010 | 11:40 PM
Black_Stallion's Avatar
Black_Stallion
If its a Automatic then Check the Linkage cabel could have loosened i had the same problem with my c6. got stuck in 1st gear. Hope it helps!
Old Jan 24, 2010 | 11:41 PM
Black_Stallion
If its a Automatic then Check the Linkage cable could have loosened i had the same problem with my c6. got stuck in 1st gear. Hope it helps!
Old Jan 25, 2010 | 01:04 PM
victorminisan
i allready did that
Old Jan 25, 2010 | 01:06 PM
victorminisan
i did that also, but thanks for the help
Old Jan 25, 2010 | 01:20 PM
ri_truck_guy
How about noises....any sound coming from it at all?
Old Jan 25, 2010 | 02:11 PM
dustybumpers
check the vaccume line from the intake to the lsteel line going to the trans, and check it from the steel line to the modual at the back of the trans above the crossmember
Old Jan 25, 2010 | 05:50 PM
86bigred's Avatar
86bigred
when you check the dip stick smell the fluid on the end,and see if it smells burnt.
Old Jan 25, 2010 | 10:48 PM
ctubutis's Avatar
ctubutis
Put the rear end up on jack stands, have somebody "drive" it, crawl under there and see
what you can see while they do that. Although it's unlikely given your description, there's
always the possibility of the rear end having a problem.
Old Jan 26, 2010 | 01:10 AM
sivart's Avatar
sivart
My first thought was 'broken axle'
When my axle broke, it was just like the truck went into neutral.
