Brake shoe question
Old Jan 25, 2010 | 11:25 AM
Talyn's Avatar
Talyn
Originally Posted by joe_13894
OK, one more time here...
Go check on any online parts store. The DRW has 3 1/2" brake shoes AND the drum is bigger around; 12 1/4" instead of 12".
I just did mine. I had to take the drum to a heavy duty machine shop because the regular auto machine shop couldn't turn anything over 12"
Not true.
Originally Posted by RRranch
There are 3.5 inch ones on some of them. I think drw with 4x4 is all. It's not very common. It was an option though. I remember that. HD braking system for the camper package if I remember right. Mine has the camper package and trailer tow package, SRW with sway bars and factory overloads and it has the 3 inch shoes.
If I go to a parts store to get shoes here I know none of their computers will tell them the right ones. I'm going to get new linings for mine next month and reline them myself. It's easy and a whole lot cheaper to do that way. Those 90 dollar extreme duty ones at Oreilleys can be done with the exact same linings my way for 15 bucks!
Most places won't turn these drums. I wouldn't even recommend letting a regular car garage do it. Find a place that actually relines clutches or brakes for big trucks and you will be a lot better off.
As Dan here has corrected the Previous poster.
The 3.5 is not "standard" but an option like RRanch stated.
If you go to the parts store and tell them what you have, it will list a 2 1/2 or a 3 inch rear pad for our truck, but will not state DRW or SRW for them.
I figured the DRW's would have bigger brakes, but its the other way around.
I think the 3 1/2s were for Utility trucks.
Explain what your talking about there Dan with the whole re-lining the drums.
You talking bout turning them down and throwing and pressing an insert into them to reuse the old drum? I might need to do that. Mine are toast.
Old Jan 25, 2010 | 01:40 PM
RRranch's Avatar
RRranch
I meant relining the shoes. That's easy. just drill out the rivets, sandblast and repaint the metal part, glue AND rivet on a new lining, bevel the edges on the belt sander and good to go. I did tons of them at tractor dealers. Clutches too.
Those 3.5 inchers are found on utility trucks also. Had to work on a few of those. I do think the 2.5 has more surface area due to the longer shoe and a bit more diameter on the drum. Id have to do the math but I''m sure they are more friction surface on that one.
Old Jan 25, 2010 | 03:14 PM
joe_13894's Avatar
joe_13894
Right from the NAPA website:
NAPA NB 4401472
1996 Ford Truck F250 3/4 Ton - Pickup
Comments: w/ 12" X 2 1/2" Brakes
NAPA NB 4401469
Comments: w/ 12" X 3" Brakes.;Over 8,500 lb. GVW
1996 Ford Truck F350 1 Ton - Pickup
Comments: w/ 12" X 3" Brakes.;w/ Single Rear Wheels;5.31" Drum Width
NAPA NB 4401482
Comments: w/ 12 1/8" X 3 1/2" Brakes;w/ Dual Rear Wheels
My truck is a 2 wheel drive pickup, and has the 3-1/2" brakes.
Old Jan 25, 2010 | 07:18 PM
Talyn's Avatar
Talyn
You should get the report for your truck, that will tell you why you have 3 1/2's unless somebody upgraded them to that.
Pele
Feb 26, 2017 09:37 AM
mattjarma
Nov 13, 2016 11:16 AM
cosmonihilator
1997 - 2003 F150
Sep 8, 2016 03:40 PM
cixelsyd
1997 - 2003 F150
Aug 19, 2015 05:45 PM
94' 460 F350
Sep 12, 2007 07:46 PM
