Sponsored by: Real Truck
BFG vs Goodyears
Old Jan 24, 2010 | 02:27 PM
Jigger2020's Avatar
Jigger2020
if you like BFG's then shop around & get an alingment,Gigger
Old Jan 24, 2010 | 03:22 PM
seminaryranger's Avatar
seminaryranger
I'm sooo over BFGs.
The Goodyear Silent Armors get the nod. My dad put a set on his 2500HD after using BFG A/Ts for the past 10 years. I ran their Mud Terrains for years as well. Their tires are OK, but they're not the be-all-end-all my buddies make them out to be. The BFG A/Ts are terrible in mud but decent on the road. The Silent Armors feel more stable in standing water, while mud performance seems similar to the BFG A/T.
Old Jan 24, 2010 | 05:07 PM
kjf-250's Avatar
kjf-250
@seminaryranger
I like the silent armors too but the problem is to get an 20inch E-rated they are $355.
Old Jan 24, 2010 | 06:23 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you go to discount tire, they may be able to give you some credit on your old tires if it's something they sell. Seeing as I'm going into my third set of BFGs, they gave me a credit based on the remaining tread, so instead of paying $1200 out the door, I'm only paying $751 for the whole package. (certs, lifetime rotation, and balance)
Old Jan 24, 2010 | 07:03 PM
Fully_Loaded's Avatar
Fully_Loaded
I will have to say that I have run the 285/75R16 Load range E on my truck since I bought it and get between 60 and 70K per set and that is changing them right when they get to the wear bars. I tow all the time and absolutly love them. Every pair of goodyears I have ever owned have cupped and wore terribly. I rotate about every 10K unless I do a lot of in town then I rotate at 7K. I also would not put a tire other than an E rating unless you never tow. These trucks are heavy and need the extra sidewall strength to keep them from flexing. BFG definatly.
Old Jan 24, 2010 | 11:18 PM
capn kirk's Avatar
capn kirk
just went back to bfg at about a week ago they get my vote
Old Jan 25, 2010 | 06:24 AM
blockmanjohn's Avatar
blockmanjohn
No one has mentioned much about performance in snow. I plow with my truck so it is important to me. Thanks, John
Old Jan 25, 2010 | 07:45 AM
Cowboy65's Avatar
Cowboy65
I've run Goodyear & BFG's both and give my vote to BFG's. For me they perform better all the way around (dry, wet, mud, snow). The mileage is not quite as good but I think that's because the rubber seems to be a little softer. If you haven't already check out the prices at your local Walmart or Sam's tire center. I called places in three counties when I bought my last set and Walmart was by far the best price.
Old Jan 25, 2010 | 10:08 AM
Ace!'s Avatar
Ace!
I find that snow conditions can vary so greatly that it's even harder to recommend a tire for snow (wet, heavy, light, powder, packed, etc.). I have run BFG AT/KO tires in the snow and they worked very well. I've also run Cooper STT while driving with a number of guys with Toyo MT. The Coopers worked well in anything other than packed snow, when they were new. They worked better than the Toyos; however, now that the Coopers have worn they are not performing well in snow. I'd much rather have BFG AT/KOs in snow than my Coopers.
Old Jan 25, 2010 | 10:38 AM
CampD's Avatar
CampD
I've gone thru a min 6 sets of BFG AT's all while plowing and personaly will not use any other tire. They have performed very good even when getting towards the end of their life. New truck has 30k on the original GY's
and will soon be getting new BFG's. I've heard guys recomend GY at's but
I dont think I can switch.
