HELP!!!
Old Jan 23, 2010 | 10:02 PM
btacarlton's Avatar
btacarlton
Exclamation HELP!!!
Just pulled the oil filler cap off to start an oil change and this is what I saw. Smells like oil and fuel, but doesn't look like oil
There is more in the top of the filler tube. Any ideas?
Old Jan 23, 2010 | 11:12 PM
javieljb's Avatar
javieljb
I'm not a mechanic, but it looks like water mixed with the oil. Head gasket leak? Does it run ok? Rough idle? Is your coolant level low?
Good luck.
Old Jan 23, 2010 | 11:24 PM
Gearbanger 101's Avatar
Gearbanger 101
Does the oil on your dipstick resemble that, or just your oil cap? If its just the cap, its really nothing to worry about. That's condensation mixing with the oil, most likely due to a few too many short duration trips without letting the vehicle warm up to full operating temperature.
Do you live only a couple of miles or so from work/school by chance?
Old Jan 23, 2010 | 11:33 PM
btacarlton's Avatar
btacarlton
Just in the cap and in the top of the filler neck. I don't live close to work though, but I'm sure I am guilty of a few trips to the gas station or store with out fully warming the truck up. Hopefully that's the issue. Truck runs fine. Thanks.
Old Jan 24, 2010 | 12:52 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
hate to say this phrase...but, "that is normal"
the 5.4 3v motor loves to condense water from the atmosphere. and short trips don't get the motor hot enough to burn that water off and get sucked out the motor via the PCV
just wipe it out, and try to avoid those short trips...especially in the colder weather
Old Jan 24, 2010 | 12:55 AM
bsocko's Avatar
bsocko
Agreed, totally normal. Mine has the milky substance on the cap all the time.
Old Jan 24, 2010 | 09:25 AM
btacarlton's Avatar
btacarlton
Thanks everyone.
Old Jan 24, 2010 | 11:40 PM
tbear853's Avatar
tbear853
Yeah, it's just where the moistue in the air over the warming oil / internals condenses against the cooler under surfaces of things like caps and valve / cam covers and mixes with oil mist. Thoroughly warming the engine warms those surfaces as well. It ain't all your oil.
Sanddriver
19
Oct 29, 2013 11:52 PM
GreatNorthWoods
21
Oct 10, 2012 09:46 AM
deemac
26
Oct 12, 2009 09:17 AM
morgan867
2009 - 2014 F150
56
Jan 1, 2009 02:59 PM
uc4me
Jan 28, 2008 08:26 PM
