tranny issues
Old Jan 23, 2010 | 11:06 AM
bigdummyford's Avatar
bigdummyford
tranny issues
I just got my truck BACK out of the tranny shop, had it rebuilt a month ago on warranty and it ended up being the master kit and an RV torque converter. well on day one it slipped and acted like it didnt want to shift out of 3rd gear, added a qt of fluid and it was ok. well last weekend hauling my brothers f-250 again, last time it was brakes, this time a locked up 351, it started flashing the overdrive light and wouldnt shift above third again. Well long story short the tranny shop replaced the solenoid pack and now i want to put it through its paces. ANY SUGGESTIONS ON HOW TO DO SO BEST? ALSO, is the solenoid pack the same thing as the valve body controlling the shifting, maybe someone can school me on how our tranny operates there.
Old Jan 23, 2010 | 11:30 AM
mueckster's Avatar
mueckster
The solenoid pack is used by the PCM to control when the TC & coast clutch lock up and the shifts occur. The Accumulator VB sets the duration of the shifts and their firmness. Firmness is also controlled, to a certain extent, through the EPC (electronic pressure control) solenoid by the PCM.
Old Jan 23, 2010 | 11:36 AM
Jigger2020's Avatar
Jigger2020
Yes the solenoid pack is in the pan area beside the valve body,it tells the tranny when to shift,Gigger PS keep your eye on the fluid level to make sure it is not leeking somewhere,tranny's don't use up fluid like a motor uses oil sometimes.
Old Jan 23, 2010 | 11:39 AM
DieselCamper01's Avatar
DieselCamper01
Miles, you have been having some lousy luck lately. Hope this goes well this time around
Old Jan 23, 2010 | 11:41 AM
mueckster's Avatar
mueckster
The solenoind pack also includes a TFT (trans fluid temp) sensor to monitor the fluid temp for cold and warm shift strategies.
Old Jan 23, 2010 | 11:46 AM
Jigger2020's Avatar
Jigger2020
If you want to put the tranny through a work out ,just put lot's of miles on it and tow a Chevy out of the mud or something,Gigger
Old Jan 23, 2010 | 12:02 PM
bigdummyford
misfortune for sure
well I was wondering if the john wood valve body would be easily installable or if there is something else i can do with it to keep it shifting good. Do the solenoid packs short and mess up pretty often then?
Old Jan 23, 2010 | 12:07 PM
mueckster's Avatar
mueckster
I don't think it is a common problem. I haven't heard of a rash of failures. I feel a modded accumulator VB is a good investment and are fairly easy to do. Just a bit messy.
Old Jan 23, 2010 | 12:09 PM
Jigger2020's Avatar
Jigger2020
I agree,the best thing anyone can do is service the fluid & filter regularly,Gigger
Old Jan 23, 2010 | 11:08 PM
MiamiPSD's Avatar
MiamiPSD
JW VB is an excellent upgrade. Last week I installed mine which I got from Clay, shifts sweet. I also went ahead before the VB, installed a Precision Stallion 3 disc converter and had Jody swap out my old rotary DP tuner for a DP 5 tuner with upgraded tunes to match the add ons. What a difference with this package. I drive my truck in the 80 setting and grin at each shift. My next add on is the external transmission filter set up which should be getting to me sometimes next week.
Old Jan 24, 2010 | 10:49 AM
bigdummyford
anyone have a picture of the valve body out of our trucks? isnt the valve body a bunch of solenoids? I know what the valve body is in a C-6, but thought i read something different bout the 4r100
Old Jan 24, 2010 | 06:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The solenoid body is a bunch of solenoids. The valve body looks similar to a C6 valve body.
