I assume they are. I searched the archives and found references that say do not use paper material type gaskets and I remember someone suggesting copper a number of years ago. Is that what is meant by non paper or are there other types that are better or worse? I want whatever is best. I hate leaky headers! I am dropping my 460 back in my '79 F-150 SWB 4x4 this week. It has L&L fenderwell exit headers. Thanks for any advice. Also does anyone have any suggestions for header gasket vendors? Are they all the same or does quality vary?
You get what you pay for in header gaskets. I would still use some sealer on the copper ones. 460 gaskets will go on either way. One way shuts off about 1/4 of the opening, so make sure you get them on the right way. Keep checking the bolts, for a long time.
ok great, i dont mind spending more for a better product. Any brand suggestions? How about suggestions for sealant? Is there actual header sealant available or is it more of a type of RTV??
I don't use gaskets at all. Buy a tube of the copper rtv, put some on the head and some on the headers and torque them down. Never had a leak doing it this way.
How about for your everyday daily driver? Will the RTV work well without burning up?? How long will the RTV last if using for headers gaskets???
Thanks im getting ready to bolt up a new set of Doug Thorleys to my 1988 460 EFI motor and with all the emission junk around the headers the last thing i want to do is retorque header bolts or worse yet replace the header gaskets
I just finished my 460 reinstall (also with L&L fenderwells) and used Remflex graphite gaskets combined with stage 8 header bolts. The gaskets are VERY thick, and compress about 50% to help seal imperfections, and their cost isn't that much more than a set of paper gaskets. The bolts have a clip thingamajiggie (for lack of a better word) that keeps them from rotating back out. They were however obscenely expensive. (about $4.00.... per bolt) So far, no leaks, but it hasn't been many miles since install. I heat-cycled and retorqued twice before installing the locking clips. As a side note to those with experience with backwards gaskets, how much hp (on a nominal 400 hp engine) do you think I was losing with one side gasketed backward?
I got mine locally at Baxter's Auto Parts. I think that they're primarily a northwest outfit/ quasi-speed-shop. I've seen them online at Summit, and I imagine Jegs has them as well. Couple of things to look out for. Unless you have CJ heads, and I doubt it, make sure you get the 3010 gaskets and not the 3011. Easy mistake for a less than knowledgeable counter guy to make. Also, regarding the bolts, when I pulled the headers, I removed 3/4" ARP bolts that the previous owner had installed the L&Ls with. So, if you can image, about a half an inch of flange combined with another 16th or so of gasket doesn't leave much length for penetration. I would suggest at least one inch bolts, and perhaps test fitting a 1-1/4 and seeing if you have the depth for that. (I did, but I'd already purchased the 1" bolts.
I've had good luck so far (3 months) with Remflex gaskets. Don't buy them from remflex, they want $40 + shipping, I got mine from Amazon for $29 with free shipping. I've only retorqued mine once on my daily driver, no leaks so far.
