6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Battery Question
Old Jan 22, 2010 | 11:27 PM
bradtm16's Avatar
bradtm16
Battery Question
Ok, here's the deal: I bought a used '08 F250 a couple months ago. I work offshore. The first time I came back in from offshore (being out 7 days) the batteries were dead. I didn't have time to mess with it during Christmas, so i went offshore again for about 19 days, batteries died again. Had the batteries tested and the one on the drivers side was bad. I replaced it with a new one.
I know having one weak battery will pull the other one down, but to make sure there isn't something drawing the batteries down also, I need ya'lls help. Does anyone know what the amperage draw is supposed to be when the truck is not running. I took both battery cables off and measured a draw of about 2.3 amps. I pulled some fuses and found that when I pulled the radio fuse it dropped the amperage draw down to about 1.0 amp. Any help would be appreciated.
Old Jan 23, 2010 | 12:16 AM
ssharber's Avatar
ssharber
Which type of radio came with your truck? Nav radio, Sirrius, 6 cd changer? I'm not an electronics expert, but when you replace these batteries, Ive heard to ALWAYS replace them both, regardless of the condition of the other one. While leaving any diesel un-started for close to a month is not good for various reasons I've heard people here say, I'd find it odd that the radio would pull down the batteries all by itself. Also, you didn't say, but did you put a charger on both batteries the first time or did you just jump it and drive? Ive seen many alternators burned up after jumping a completely drained battery and just letting the alternator push a charge in it.
Old Jan 23, 2010 | 01:01 AM
iqoair's Avatar
iqoair
The alternator will detect a full charge from your new battery and never fully charge your old battey, even if it's good. Always replace them in pairs. Are you doing the parasitic draw test properly ? Sometimes it takes several minutes for the modules to go to sleep after you disconnect the battery and reconnect it with your multimeter.
Old Jan 23, 2010 | 05:56 AM
senix's Avatar
senix
I would suggest that you disconnect both batteries, then turn the headlights on for a few minutes before testing to see if there is a draw.
Totally agree with the two battery replacement as well.
I think you are ok with the truck sitting for a few weeks without running, but when you get back you need to ensure that thing gets up to temp and work it.
Old Jan 23, 2010 | 07:14 AM
koboss1's Avatar
koboss1
if your truck is under warranty and the ford store checks your batts and finds one bad one that is all they replace
Old Jan 23, 2010 | 09:40 AM
bradtm16's Avatar
bradtm16
I have the 6 disc radio system with Sirius.
If the alternator is working properly there should be no reason it would die from having to recharge the batteries after jumping.
No, I was not doing the parasitic test correctly, I read up on it last night and am going to attemp it again today, I'll let you know the results.
I did not know about replacing both batteries at the same time, thanks.
Thanks for the help guys.
Old Jun 16, 2013 | 02:51 AM
vjsimone's Avatar
vjsimone
Solved??
Was this ever solved?? I have the same issue.
sanger440
1997 - 2003 F150
Aug 2, 2014 03:14 PM
Yoam69
Apr 7, 2014 10:35 PM
wanicholas
Electrical Systems/Wiring
Feb 18, 2014 02:15 PM
kornfanjoe
Oct 21, 2013 07:26 AM
Sledmamma
Dec 28, 2012 06:59 PM
