Selling power assist components
Old Nov 4, 1999 | 08:56 AM
75highboy's Avatar
75highboy
First off, I have a P/S gear box and pitman arm off a '76 F-150 which is in great shape ($150). Now to the power assist stuff....
Anyone interested in power assist steering components from a '75 F-250 4x4? See list below for parts I have and condition. E-mail me with any requests.
Bendix Power valve w/ends.....rebuilt 3 years ago, does not leak ($150)
2 slave cylinders.............these do leak slightly, but could be rebuilt ($40 ea.)
older style p/s pump w/pulley.works fine ($60)
brackets for pump.............from an FE motor ($20)
pressure hose(pump to valve)..new 3 years ago ($20)
pressure hose(pump to valve)..new in box ($30)
pressure hose(valve to cyl)...new 3 years ago ($30)
all other hoses...............probably original, don't leak ($10-$30ea)
I also have other parts for this truck:
ring, pinion & open diff. carrier for Dana 60-4:56 ratio ($125)
Fuel pump w/ integral filter cartridge mounted below (FE engines) ($20)
e-mail me if you need anything else, and I will check to see if I have it. BTW I'm in St. Louis area.
john
Old Nov 4, 1999 | 10:01 AM
Jeff's Avatar
Jeff
There is a seperate area for classifieds you may not be aware of. I'd hate to see this section cluttered up with a bunch of things for sale.
Old Nov 4, 1999 | 11:04 AM
75highboy's Avatar
75highboy
I am realatively new to the message board and did not realize there was a classified section. Sorry again.
john
Old Nov 4, 1999 | 12:26 PM
Uffe's Avatar
Uffe
