Idaho Chapter Idaho Chapter
Join Chapter, Leader:
Tranny fluid leak
Old 07-01-2010, 05:27 PM
supersle's Avatar
supersle
supersle is offline
Tranny fluid leak
So I towed my car up to Portland and back last weekend. Flawless and not a problem. But when I got to Boise to a friend's house I was backing the trailer into his driveway and noticed I was leaking a line of tranny fluid down his driveway and when I stopped it just puddled up. Let it sit for a while and cool off since I just drove 400+miles on it. Drove forward and no leak. Topped it off and drove 300 more miles home and still no leak. Haven't tried in reverse really other than backing out of the drive and there isn't a puddle under the truck sitting. Anyone have any ideas?
Edit: found a few suggestions searching
Pulling in reverse will get the trans hot in a hurry.... The front seal can and does flip causing aleak, it might return to normal after it cools down but, eventually it will fail though. There is a new seal (viton IIRC) that's supposed to cure it.
Old 07-01-2010, 07:04 PM
im2tall33's Avatar
im2tall33
im2tall33 is offline
hmmm? i dont know..i would try posting this in the v10 section and the larger truck sections.. they could deffinatley help you out..seems kinda odd though..
Old 10-15-2010, 08:43 AM
gearhead351's Avatar
gearhead351
gearhead351 is offline
Might have started to over heat the trans fluid. Fluid expands as it gets hot. Or did you back up an incline? Slip yoke might have just moved and allowed fluid to pass temporarily until the "load" was taken off the shaft. (thats what she said) ahaha.
Im2Tall I happen to live in couerdalene as well!
cptaylor
06-29-2014 06:19 PM
Hotel
06-12-2014 06:48 AM
kenko
06-03-2012 03:19 PM
Awitte58
06-03-2011 09:02 AM
mark73f250
08-31-2004 03:40 PM
Quick Reply: Tranny fluid leak
