Ford E150 mass air conversion
Old Jan 22, 2010 | 01:18 PM
tyler2009's Avatar
tyler2009
Well my van has the 5.8l and the e4od tranny looking for some help on what i need to do it liike what ecm from the f150s i can use and so on..
Old Jan 22, 2010 | 02:45 PM
Conanski's Avatar
Conanski
It's has the exact same powertrain as the F series trucks so you need a 5.0 or 5.8 E4OD computer and harness.
Old Jan 22, 2010 | 02:54 PM
tyler2009's Avatar
tyler2009
Could you look on this ebay page Car Truck Parts, Parts Accessories, Exterior, Lighting Lamps on eBay Motors and tell what one i can use.
Old Jan 22, 2010 | 03:00 PM
tyler2009's Avatar
tyler2009
what about this one 96 F150 / BRONCO 5.0 E40D AT ECM ECU ENGINE COMPUTER : eBay Motors (item 140368488870 end time Feb-16-10 11:10:00 PST)
Old Jan 22, 2010 | 03:24 PM
tyler2009's Avatar
tyler2009
Old Jan 24, 2010 | 01:05 PM
tyler2009's Avatar
tyler2009
Will any of the ECU work that i listed? And wanted to know what you used to do your conversion with.
Old Jan 24, 2010 | 03:16 PM
Conanski's Avatar
Conanski
You need one of the EECs listed below. My truck is older and has a non-computer controlled AOD transmission so I was able to use a Ford conversion kit that utilizes a Mustang computer.
<TABLE style="WIDTH: 473pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=631 x:str><COLGROUP><COL style="WIDTH: 48pt" width=64><COL style="WIDTH: 80pt; mso-width-source: userset; mso-width-alt: 3913" width=107><COL style="WIDTH: 49pt; mso-width-source: userset; mso-width-alt: 2377" width=65><COL style="WIDTH: 56pt; mso-width-source: userset; mso-width-alt: 2742" width=75><COL style="WIDTH: 48pt" span=3 width=64><COL style="WIDTH: 96pt; mso-width-source: userset; mso-width-alt: 4681" width=128><TBODY><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 height=18 width=64>Engine</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=107>Vehicle</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 49pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=65>Year</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 56pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=75>Efi type</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=64>Trans</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=64>Diff</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=64>Code</TD><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 width=128>Part Number</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 473pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=631 table x:str><COLGROUP><COL style="WIDTH: 48pt" width=64><COL style="WIDTH: 80pt; mso-width-source: userset; mso-width-alt: 3913" width=107><COL style="WIDTH: 49pt; mso-width-source: userset; mso-width-alt: 2377" width=65><COL style="WIDTH: 56pt; mso-width-source: userset; mso-width-alt: 2742" width=75><COL style="WIDTH: 48pt" span=3 width=64><COL style="WIDTH: 96pt; mso-width-source: userset; mso-width-alt: 4681" width=128><TBODY><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; WIDTH: 48pt; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18 width=64>5.0L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Bronco, Pickup</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 49pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23 width=65></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 56pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23 width=75>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23 width=64>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23 width=64 x:num>3.55</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23 width=64></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; WIDTH: 96pt; BORDER-TOP: #ece9d8 0.5pt; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23 width=128>F5TF-12A650-GB</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.0L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Bronco, Pickup</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl26></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>HOG0</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=128>F4TF-12A650-AAA</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.0L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Bronco, Pickup</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl26></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>U4X0</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=128>F4PF-12A650-AA</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.0L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Bronco, Pickup</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl26 x:num>4.1</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>VEX1</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=128>F5TF-12A650-HB</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.0L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Bronco, Pickup</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl26></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>WAY1</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=128>F5TF-12A650-JB</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.8L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>Lightning</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>93-95</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>AKC0</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>F8TF-12A650-NA</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.8L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Lightning</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl26 x:num>4.1</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>BIO0</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=128>F5TF-12A650-BYA</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8 0.5pt; BACKGROUND-COLOR: transparent; HEIGHT: 13.5pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl24 height=18>5.8L</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 80pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=107>Lightinng</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>MAF</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl25>E4OD</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl26></TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: transparent; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl23>AKC0</TD><TD style="BORDER-BOTTOM: #ece9d8 0.5pt; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: white; WIDTH: 96pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8 0.5pt" class=xl22 width=128>F8TF-12A650-NA</TD></TR></TBODY></TABLE>
Old Jan 24, 2010 | 03:22 PM
tyler2009's Avatar
tyler2009
Should i use one for thr 5.0 or 5.8 well i think i can get the computer but i will need the harness a the maf sensor. my rear end is 3.55 gearing.
Old Jan 24, 2010 | 03:53 PM
Conanski's Avatar
Conanski
You can use either a 5.0 or 5.8 computer and the gearing doesn't really matter.
Old Feb 9, 2010 | 09:23 PM
tyler2009's Avatar
tyler2009
Will this ecm work F5TF-12A650-HB JB 120.00?
Old Feb 9, 2010 | 10:16 PM
Conanski's Avatar
Conanski
It's on the list so yes.
Old Feb 11, 2010 | 04:28 PM
tyler2009's Avatar
tyler2009
well i got a hold of two different ecm one is F5TF-12A650-HB, F5TF-12A650-J+B witch one should i use. And where do i go from there like parts wise?
Old Feb 16, 2010 | 10:05 AM
tyler2009's Avatar
tyler2009
anyone help
Old Feb 16, 2010 | 10:41 AM
Conanski's Avatar
Conanski
Either will do, and now you need a MAF meter and engine wiring harness from a '94-95 F150.
scubaguy2011
Mar 27, 2015 05:26 AM
WoeIsMe
2009 - 2014 F150
31
Jan 12, 2014 03:37 PM
econoconvert
Modular V8 (4.6L, 5.4L)
Sep 20, 2012 12:59 AM
azaan1016
2004 - 2008 F150
Jun 28, 2011 05:06 PM
MustangJim01
Apr 13, 2004 07:27 PM
