Cleaning battery terminals
Old Jan 22, 2010 | 09:54 AM
Gage2502's Avatar
Gage2502
Hey guys going to be replacing the battery in my 2000 Expedition 5.4L soon and I wanted to know a way to clean the battery terminals.
I think I might go with the Walmart battery or Interstate battery, any other ones I should look at? I was looking at the Optima but dont know how many dealers are out there for that brand. I would like a Nationwide wide warranty for it too.
Thanks again ~Gage~
Old Jan 22, 2010 | 09:58 AM
MisterCMK's Avatar
MisterCMK
I would pick up an Interstate battery. I've had good luck with them or a Motorcraft battery.
As far as cleaning the terminals, head down to your local tool store or parts store and pick up a batter terminal cleaning tool. It has a wire brush that you put over the terminals to clean and then you can pull the end off and it has a wire brush to clean out the battery connectors.
Old Jan 22, 2010 | 10:10 AM
Gage2502's Avatar
Gage2502
Ya I have that wire brush tool but I have some corrosion building up on the terminals that connect to the battery.
Gage
Old Jan 22, 2010 | 10:42 AM
alloro's Avatar
alloro
Go to home depot, a hardware store, or an electrical supply house and pick up some Noalox. Smear some all over each battery terminal before connecting it to the battery and you'll never see corrosion on them again. Forget about those battery rings at the auto stores, they don't last.
Noalox Anti-Oxidant Compound - .5 oz. Tube - ComputerCableStore.com
Old Jan 22, 2010 | 08:40 PM
MisterCMK's Avatar
MisterCMK
Gage
Try Coca Cola on them if you can't brush everything off.
Old Jan 22, 2010 | 08:42 PM
MisterCMK's Avatar
MisterCMK
I've had good luck with the felt washers on my vehicles. It is a lot less messy than the Noalox and I have a tendency to manage to get noalox or anti-seize all over my hands and every rag I have out.
Old Jan 22, 2010 | 09:09 PM
mudder1_2000's Avatar
mudder1_2000
The cheapest and simplest way is to take baking soda and water, make a thick but runny paste and pour it onto the terminals. Let is sit and rinse off. Apply Dielectric grease to the new battery posts and terminals to help stop further corrosion
Old Jan 22, 2010 | 09:27 PM
MisterCMK's Avatar
MisterCMK
The corrosion is caused by the gasses escaping around the posts.
Old Jan 23, 2010 | 09:16 AM
Gage2502's Avatar
Gage2502
Thanks guys for all the information, I will let you know what battery I decide to get.
~Gage~
Old Sep 30, 2020 | 06:06 AM
tibadoe's Avatar
tibadoe
My '17 just rolled past the 3 year mark. No battery issues (or any issues for that matter) - they both still look new & no corrosion. It's not my daily driver so for me the key is keeping the cells topped of correctly and on a tender/desulfator when not driving.
handyandy123
Nov 9, 2017 12:10 AM
drewdole
Jul 3, 2017 08:39 PM
WQ59B
1947 and Older Ford Trucks
15
Mar 23, 2016 06:29 AM
Caldwell F150
Feb 24, 2016 02:33 PM
LAikens
1997 - 2003 F150
Sep 16, 2011 07:13 AM
