5sp Tanny
Old Jan 21, 2010 | 02:22 PM
coolguy1419's Avatar
coolguy1419
5sp Tanny
I've got a 86 F150 4x4 300, offy dp intake, Edelbrock 1403 carb, efi manifolds, 9" rear 3.73 gears, 4sp od non granny geared. I am wanting to switch over to a 5sp. Either a M5R2 or a ZF S542 which ever one I can find. I don't do to much towing so I know the M5R2 would be ok for me but would rather have the ZF. I do alot of highway and in town driving. Do alittle off roading. I am wanting to know will these trannys bolt right up to my motor? I know Im gonna have to do some changing on the slave cylinders since these are internal slaves and mine is external. Also will current driveshaft work or have to change? What are your guys opinions? Is this a good switch? Any help appreciated Thank You!
Old Jan 21, 2010 | 04:04 PM
85e150's Avatar
85e150
This will be a very good switch.
Even the M5OD has a lower first, gets rid of the 2nd to 3rd gap, and still has OD. ZF is a little wider, but still more better imo.
You could get lucky and find an '87 with everything you need.
IIRC, someone here posted it as a simple swap, bolt in.
I would measure the existing trans and cross member locations, & take a pic of the cross member before looking for parts. You may need the newer cross member. Ditto the driveshaft.
Sorry I can't be more specific--my plans to do this swap never happened, but there are other posts here talking about it. If I find one, I'll post a link.
Old Jan 21, 2010 | 04:18 PM
85e150's Avatar
85e150
Here's one:
https://www.ford-trucks.com/forums/9...dventures.html
Hhhmm, some info:
https://www.ford-trucks.com/forums/1...as-landed.html
That's it for now, I think the best one is over a year ago.
Old Jan 22, 2010 | 08:46 AM
chrlsful's Avatar
chrlsful
If U got a 302 there's lots on ZF conversions on
classic bronco . com
Old Jan 23, 2010 | 07:40 AM
coolguy1419
Thanks for the help. Still alittle confused they. Read through the post on those links and never really covers the years of trucks I am wanting to convert to. Im wanting to go from a 90's transmission into a 80-86 truck. Anyone else got any info? Thanks!
Old Jan 23, 2010 | 12:58 PM
flipklos's Avatar
flipklos
The sasiest way to do this is to get a truck with the same wheel base.
Take the tranny, transfercase, slave cylinder, and both driveshafts.
Any 86-96 with 300 ,302, or 351 engines will have what you need. This should basicly bolt in. The rear driveshaft might be an issue as the 9" was not too common after about 83. Everything started going 8.8"
Old Jan 23, 2010 | 12:59 PM
flipklos's Avatar
flipklos
Unless you do a ton of highway driving and plan on keeping the truck for 5+ years this will just be a waste of money. The OD will only get you about 2mpg more on the highway.
Old Jan 23, 2010 | 08:16 PM
coolguy1419
Thanks! I do quite abit of highway driving. I do plan on keeping the truck till its dead! That could be a long time too!!
Old Jan 23, 2010 | 08:40 PM
chrlsful's Avatar
chrlsful
Sounds like a great addition to a real good rig, esp for the hwy, w/those rear gears. Does it have a D44 up front? If not, what.
Thanks,
cf
Old Jan 23, 2010 | 10:48 PM
85e150's Avatar
85e150
He's already got OD, he's looking for driveability. The ratios in the 4 speed OD create a massive vacuum.
Old Jan 24, 2010 | 01:27 AM
flipklos's Avatar
flipklos
I see.....Other then a mild durability incrase absoluly no advantage to this swap.
This is my opinion. Not a fact.
Old Jan 24, 2010 | 08:34 AM
coolguy1419
Thanks,
cf
Its got the Twin I beam up front.
Old Jan 24, 2010 | 08:41 AM
chrlsful's Avatar
chrlsful
Twin I beam
No I mean for the frnt Pumkin/Diff/chunk whatever U wanna call it...
Thanks,
cf
BTW: check ur PM n tell me what U think.
Old Jan 24, 2010 | 11:13 AM
coolguy1419
Twin I beam
Thanks,
cf
Hey I'm not to sure how to tell what it is for sure? The tags gone off of it so it's no help. How do u tell? Also didn't get anything I'm my pm?
Old Jan 24, 2010 | 01:05 PM
coolguy1419
Hey I checked its got the TTB Dana 44
