7.3 return lines
Old Jan 20, 2010 | 09:57 PM
chainsaw cowboy's Avatar
chainsaw cowboy
7.3 return lines
i've got a 1993 f350 7.3 non turbo replaced return lines from another engine... when i took off the plastic caps i thought they all had two outlets on each side .. but when putting ones back from the other engine i got one with only one outlet, i have no idea where the one with just one outlet is supposed to go any help?
Old Jan 20, 2010 | 10:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle
chainsaw cowboy,
Welcome to FTE and the IDI diesel forum.
The single outlet cap is for a turbo engine, it would go on the rear passenger side injector.
Hope you are using new O rings.
Old Jan 20, 2010 | 10:22 PM
chainsaw cowboy
thanks dave.. the engine i got that one off of was supposed to be a non turbo 7.3 1988 but in any case what you're saying is the 7.3 lines all have two making a comple cirlce... with the ones on the corners being closer together?
Old Jan 20, 2010 | 10:30 PM
chainsaw cowboy
I think i got lost in here... any way thanks the engine i got that one off of was supposed to be a 1988 7.3 but in any case what you're saying is the 7.3 lines plastic caps all have two pieces making a complete circuit? with the ones at the corners being closer together?
Old Jan 20, 2010 | 10:41 PM
starmilt's Avatar
starmilt
It goes on the drivers side front on the non turbo.
Old Jan 20, 2010 | 11:20 PM
tecgod13's Avatar
tecgod13
I'll second that, as thats where there is one on mine. For an aftermarket ATS install, both the driver side front and passenger side rear would be single caps.
Old Jan 21, 2010 | 08:02 PM
Dave Sponaugle
I have seen them routed so many different ways it's not funny.
Basicly, all injectors, the IP and fuel filter all have return lines on them.
There is a return line at the rear of the drivers side head that goes down to the fuel selector valve.
So if you tie all of those things together with return lines, you are good to go.
Exact routing is not important.
My 6.9 had double nipples on both front injectors, filter return went to the passenger side front injector, IP went to the drivers side front injector.
Then both sides ran straight through all the injectors to the rear injector on each side, again with double nipple caps.
The second line on both rear injectors went to the tee at the return line going to the FSV.
On my turbo engine single on the rear passenger side, up to the front injector, then over to an inline tee for the fuel filter, under the IP to another tee for the IP return, then on to the drivers side front injector. Run to the back on the drivers side, then into the line to the FSV.
celsoglima
1983 - 2012 Ranger & B-Series
Dec 16, 2016 09:06 AM
Ford4Life7.3
Dec 22, 2013 01:07 AM
chrismanjoa
Feb 18, 2012 05:05 PM
KAT_Ayanami
Nov 28, 2011 03:46 PM
BigOly
Nov 12, 2007 09:02 PM
