Sponsored by: Real Truck
Fuel Expansion
Old Jan 20, 2010 | 07:37 PM
tperk100's Avatar
tperk100
Fuel Expansion
Does anyone know at what percentage diesel fuel will expand with heat?
Thanks
Ony 3 more posts to go.
Old Jan 20, 2010 | 08:04 PM
Monsta's Avatar
Monsta
Sit. Stay.
The thermal expansion coefficient of Diesel is 0.00046/°F. Assuming constant atmospheric conditions.
Example: 1 gallon pumped in a receptacle at 60° and then goes to a 150° environment.
Increase in Volume @ 150°F = (150°-60°) times 0.00046 = 0.0414 Gallons
Old Jan 20, 2010 | 08:28 PM
tperk100's Avatar
tperk100
Daggone it!...I am done...gonna put my sig up now!
Old Jan 20, 2010 | 10:53 PM
redford's Avatar
redford
FTE Leadership Emeritus
Actually not. Your formula is off a little. Your formula assumes a linear expansion (you basically multiplied 1 gallon of fuel by 1.0414 90 times) but the expansion (if charted) is actually a curved line, not linear.
Why is that, you may (or may not) ask? If a gallon of fuel goes from 60 to 61, it becomes 1.00046 gallons. Go from 61 to 62, then you need to multiply 1.00046 times 1.00046, for 1.00902, then again and again...88 more times.
This slight error widens as the temp climbs. By the time you reach 150 degrees, you would have 1.0422599 gallons of fuel, not 1.0414 gallons.
'94IDITurbo7.3
25
Mar 16, 2012 12:36 PM
jimmyburg
Alternative Fuels, Hybrids & Mileage
Apr 18, 2008 08:12 PM
jimmyburg
Feb 26, 2008 09:12 AM
lpbaca
Mar 29, 2005 08:16 PM
state
Oct 26, 2004 08:15 AM
