Weird Oil Pressure...?
Old Jan 21, 2010 | 03:40 PM
Brown Falcon's Avatar
Brown Falcon
Originally Posted by jleal_21
by the way brown falcon are those rims 8 in. wide or 10 in.?
16x8 Raceline Renegade 8's, 4.5" backspacing, with 285/75-16 Mickey Thompson Baja MTX's
They rub a little in front turning hard... Kinda annoying.
Originally Posted by strokin'_tatsch
Brownie, pull the oil filter back off and check the filter bypass there. on your truck it was staked in instead of being c clipped like the later trucks where and when you were messing with the cooler it could have come out. mine came out when i was pulling mine out, but i was putting in an SD end cap with the c clipped bypass anyways so i didn't care.
What does the bypass look like? I did notice a metal cylinder thing with a spring inside and another metal cylinder thing that had fallen out. I just put it back in where the hole was... can you even get to it without pulling the cooler again?
Originally Posted by RRranch
You guys with oil pressure problems really need to go wiggle that wire connector around while someone watches the gauge. I'm telling you this is the problem on the majority of them.
I'm still gonna try that when it stops raining.
Old Jan 21, 2010 | 03:50 PM
Action4478's Avatar
Action4478
Did you put it back in the correct order , then re stake it in place ?.. you can see it by un screwing the oil filter
Old Jan 21, 2010 | 04:20 PM
ckal704's Avatar
ckal704
Where is that rascal of a sending unit located? Anyone have a pic? It would surely save me some time when I go hunting for it.
Thanks!!
Old Jan 21, 2010 | 04:37 PM
Action4478's Avatar
Action4478
Kal, its on the left in the pic....
URL=http://rides[.webshots.com/photo/1265789141055156552HBnVSm][/URL]
Old Jan 21, 2010 | 04:55 PM
Brown Falcon
Originally Posted by Action4478
Did you put it back in the correct order , then re stake it in place ?.. you can see itby un screwing the oil filter
Good question... I probably didn't...
Old Jan 21, 2010 | 07:06 PM
Hussler's Avatar
Hussler
OK, I'll bite. How do you re-stake in in there? Is it a press fit?
Also what is the "theory of operation" on what it does and how it works?
I thought is was to ensure low oil pressure was flowing to HPOP reservoir on cold starts, but it seems to be a bypass valve to the c-case?
Brownie, I feel you pain. Fixing one problem just to get this other.
Old Jan 21, 2010 | 08:45 PM
yoslick's Avatar
yoslick
If the filter becomes clogged/plugged the oil reroutes from the filter thru the bypass back to the cc. Your gonna need a small chissel or garbage screw driver to make a notch with a hammer in 3 spots to hold in the disc and spring, should be able to see where they already are and just redo them..
Old Jan 21, 2010 | 08:59 PM
Hussler's Avatar
Hussler
Thank you for that explanation. Knowledge is a very powerful tool.
Now the question is .. what the heck is a garbage screw driver?
Old Jan 21, 2010 | 09:10 PM
yoslick's Avatar
yoslick
you know, that one you like to hit with a hammer and use for scraping gasket material that says craftsman on it and gets returned every so often for a new one!! lol
Old Jan 21, 2010 | 10:42 PM
strokin'_tatsch's Avatar
strokin'_tatsch
i couldn't help but laugh at this one!!!!!!
Old Jan 21, 2010 | 11:39 PM
jleal_21's Avatar
jleal_21
what would happen if we were to drive the trucks like this for a while?
Old Jan 22, 2010 | 05:36 AM
ckal704's Avatar
ckal704
Thanks for the picture, Rick. I know what a sending unit typically looks like and can see it clearly in the picture. What general area of the engine am I going to be looking at? I see what looks to be some coolant hoses there. I read somewhere that the thing is at the top rear of the engine near the firewall. Correct?
I am tied up with work most of the day Saturday and I am hoping to be home in time to have enough daylight to pop a new one in (and solidify the connection) on Saturday afternoon.
It doesn't help that everything is so clean and shiny in your photo either! Kinda like reverse camouflage trying to find the same stuff on a dirty engine!
Old Jan 22, 2010 | 07:53 AM
  #28
Action4478's Avatar
Action4478
Kal, Its right on the front of the motor ,rectangular resevoir, might be under the engine cover (if you have one )
Old Jan 22, 2010 | 07:54 AM
  #29
Action4478's Avatar
Action4478
I would suspect that some of the oil is by passing the filter ...
Old Jan 22, 2010 | 08:00 AM
  #30
strokin'_tatsch
definitely not on the rear of the engine.. front of engine on top of the HPOP reservoir on the left side if your standing in front of your truck....
