Aerostar Ford Aerostar
that was fun
Old Jan 20, 2010 | 02:01 PM
R-TypeEman's Avatar
R-TypeEman
that was fun
my van has had a coolant leak for the last few years, not much, just needs a topup every few months. well on saturday it decided it was time to spray. went through 3x4liter bottles of water in 15 minutes to drive it out to fix it.
initially we had thought it was a headgasket gone bad - luckily it was much easier than that - the front cover gasket failed up at the top. new gaskets were ordered for the front cover and water pump, everything was reinstalled and its all good for another few years.
while we had everything apart, we discovered why the airconditioner had failed: both lines running to the rear of the compressor were rusted through.
i had planned to swap my engine mounts, but after seeing how the one bracket has collapsed, im going to leave them until i get "new" brackets from a donor van as i cant find them anywhere online.
at least i have decent heat now
Old Jan 20, 2010 | 07:26 PM
Aeroman59's Avatar
Aeroman59
Did you have to remove the timing chain etc? How did you trace the leak before it sprayed?
Old Jan 20, 2010 | 08:37 PM
R-TypeEman's Avatar
R-TypeEman
we couldnt see where it was coming from until we removed the alternator bracket, we could see exactly where it was seeping out from (we had mostly drained out the coolant)
timing chain wasnt even touched, it was exposed, but no need to remove
PaysonPSD
37
Nov 12, 2018 10:35 PM
KhanTyranitar
Aerostar
20
Aug 12, 2014 06:15 PM
Allen72289
Mar 30, 2012 12:25 AM
rickatic
Mar 10, 2010 09:46 PM
JBronco
1978 - 1996 Big Bronco
Jul 3, 2007 09:45 PM
