I'm adding an Aftermarket AMP and Speakers this weekend. I know Crutchfield is good about providing documentation, but am looking for info on Factory wiring for Speakers and the SUB.... Does anybody have the color list ???
Completed the install of aftermarket amp, speakers and sub... OMG what a PITA (pain in ..)... To keep the functionality of the rear seat controls, I had to splice into the factory harness behind the radio, run to the amp inputs and right back from the amp outputs..... It's DONE.... sounds great as well.....
Rockford Fosgate 5 channel amp (for sub power as well)
Rockford Fosgate 8" dual VC sub
Infinity Kappa 5x7 Door Speakers
>'01 EB Expy - Added Skid Plates.
>More when real performance parts become available
Can you help me out with the color combination,Im lost,Im doing the same,got 2 amps and subs waiting but do not have any idea where to tap in,I took the radio out,car looks like a mess but I found 8 sets of cables on the connector behind the head unit,I just dont know where to tap in with the HI/Low coverters,IM LOST.
Thanks
Did you buy from Crutchfield??? I called them and they gave me the breakdown.... The only one they had wrong was the remote turn on... I ended up using the factory wiring for the speakers.. so I had to splice into the harness in the dash... from head unit to amp and then back from amp to speaker wires.....
I believe I threw away the sheet of paper I wrote the color codes down on.... Hint... the colors at the speakers don't math in all cases. If you can't get them, I will try to see if Crutchfield believes I haven't installed it yet and call them again with my cust #
Infinity Kappa Speakers
Rockford Fosgate Sub
Rockford Fosgate AMP
