Starter 1940's
Old Jan 19, 2010 | 01:54 PM
Griff52's Avatar
Griff52
Starter 1940's
Hi all, dumb question but here goes what year did they stop using floor starter button?
Old Jan 19, 2010 | 09:15 PM
46fordtruck's Avatar
46fordtruck
I think it may have been '37 when Ford went to dash mounted push buttons. But other makes continued them into the '40's. We have a '41 Plymouth truck that uses the floor mounted starter.
Old Jan 20, 2010 | 03:39 PM
Dan Robertson's Avatar
Dan Robertson
A 59 Chevy Viking had a floor mounted starter button.
Old Jan 21, 2010 | 05:16 AM
Griff52's Avatar
Griff52
Thanks,my 1947? I think is a '42 has a floor mounted starter button,that with the serial numbers point that way
Old Jan 21, 2010 | 08:12 AM
COMPLIT1107's Avatar
COMPLIT1107
Check again.. It actually may be the high-beam switch. When I pulled mine (47) the wires were not heavy gauge and I believe fed into the harness which contained the headlight wiring. I wacked it all about 10 years ago but I still have switch. I'll look at it again but I think it had 3 wires, not two.
Old Jan 22, 2010 | 12:53 AM
46fordtruck
If it's mounted on the floor, by the kick panel and firewall, it's your highbeam switch, as John mentioned. Ford abandoned the floor mounted starter switch by the '40's. The starter button is mounted on the dash, just to the right of the instruments.
Old Jan 22, 2010 | 07:55 AM
Griff52's Avatar
Griff52
I checked again,it is a floor mounted starter switch to the right of gas pedal,high beam switch is by kick panel,may a 42 still have the floor mounted switch?
Old Jan 22, 2010 | 04:59 PM
46fordtruck
No, '42 does not. Sounds like that was added at a later time. Ford's trucks used a dash mounted switch, no foot switches.
Old Jan 22, 2010 | 05:42 PM
Dan Robertson
My 46 has a foot rest to the right of the accelerator. The accelerator looks more like an upside down spoon than a conventional peddle.
Old Jan 23, 2010 | 12:16 AM
46fordtruck
That's right, there is a footrest on the floors near the accel pedal, it's attached to the transmission cover on the floor. That could be what it is. Have you looked under the truck to see if there are any wires coming from what you think might be a floor mounted starter?
LloydH
Aug 8, 2015 08:19 AM
Fireman_dave
Jan 1, 2015 08:50 PM
16
Mar 5, 2014 08:57 AM
Albert Sanchez
1983 - 2012 Ranger & B-Series
Oct 28, 2013 07:44 AM
SoCalDesertRider
Electrical Systems/Wiring
Dec 24, 2002 09:24 PM
