Need Help Adjusting wheel bearings
I always use channel locks because I get a better feel for how light it needs to be when tightening the nut.
Stewart
Set the bearing with 20 ft/lbs while turning, then back off nut 3/4 turn and use your fingers with just the socket to snug it up, then about a 1/10 turn with the wrench.
I just did mine in Dec and after finger tightening, the torque wrench would break at about 1/10 to 1/8 turn.
Feels lose but its not.
If you took it for a quick spin and they got hot, way to tight.
They should bearly get warm on long trips. Unless alot of braking.
From Timkins web site:
To adjust the setting of this bearing:
Step 1: Tighten the nut while
turning the hub. When there is
a slight bind on the bearing, the
parts are seated correctly.
Step 2: Back the nut off 1/6 to
1/4 of a turn or sufficiently to
allow .001” to .007“ end play.
Note: Failure to back off adjusting
nut could cause bearing to run
hot and be damaged. Wheel
could lock or separate.
Here are the links to 2 of the Timken Tech sheets.
http://www.timken.com/EN-US/solution...gs_English.pdf
http://www.timken.com/EN-US/solution...rngSystems.pdf
Following Fords manual, I got .002 end play when I checked.
From ford manual:
Wheel Bearing Adjustment —F-250, F-350, F-450, F-550
CAUTION: Wheel seals on the front axles must be replaced any time the axle lubricants are changed from factory-installed mineral lube to synthetic lube or vice versa.
CAUTION: If bearings are adjusted too tightly, they will overheat and wear rapidly. An adjustment that is excessively loose can cause pounding and contribute to uneven tire wear, steering difficulties and inefficient brakes. Check bearing adjustment at regular inspection intervals. New wheel seals must be installed when the hub is removed. A damaged or worn seal can permit bearing lubricant to reach the brake linings, resulting in ineffective brake operation and necessitating premature replacement of linings. To check the wheel bearing adjustment, raise the front of the vehicle. Grasp the tire at the sides, and alternately push inward and pull outward on the tire. If any looseness is felt, adjust the front wheel bearings as follows.
While rotating the wheel, tighten the adjusting nut to specification as illustrated to seat the bearings. 21ft/lbs
Back off the adjusting nut until loose.
While rotating the wheel, tighten the adjusting nut to specification as illustrated. Torque required to rotate the hub should be 2 Nm (18 lb-in).
Install the castellated nut and insert a new cotter pin.
Hope this helps
From ford manual:
Hope this helps
