Sponsored by: Real Truck
Ratchet straps??
Old Jan 19, 2010 | 09:42 AM
Futuresweets-10's Avatar
Futuresweets-10
Ratchet straps??
I am having trouble finding good ratchet straps... Sams club has an okay set (good year I belive) that are ok for small loads in the bed, but they dont last too long and are no where near big enough for larger trailer loads. I had one larger/ thicker strap (3 or 4in wide I belive) that appears to be what is used on a semi. I dont know where I got it or where to find another. Where is the best place to look for good, high quality, heavy duty straps?
Old Jan 19, 2010 | 10:55 AM
Monster-4's Avatar
Monster-4
Check out a Tractor Supply Company store or a simliar chain. They carry all sorts of straps.
Old Jan 19, 2010 | 11:11 AM
sdetweil's Avatar
sdetweil
I bought mine off ebay.. 4 -10ft straps, with hook ends, 10,000lb
like these 4 HD AUTO CAR HAULER TIE DOWNS RATCHET AXLE STRAPS BK : eBay Motors (item 200428637946 end time Jan-25-10 13:19:33 PST)
Sam
Old Jan 19, 2010 | 11:23 AM
shorebird's Avatar
shorebird
Try Towpartsnow.com Strap & Ratchet Assemblies :: Towing Equipment :: Tow Parts Now
Also AW Direct; Cargo Straps and Accessories
Old Jan 19, 2010 | 11:25 AM
TBRADSIM's Avatar
TBRADSIM
go to trucking center big semis they usually have good straps.TBRADSIM
Old Jan 19, 2010 | 12:02 PM
dkf's Avatar
dkf
McMaster-Carr
Page 1535
You'll want the Wire Hook, unless your hooking onto flat trailer frames all the time. I bought mine at a local farm supply store but they are like the ones in the link with the heavy duty yellow poly straping and wire hooks. Mcmaster isn't the cheapest but they have what you need.
Old Jan 19, 2010 | 05:31 PM
Wagion's Avatar
Wagion
Lowes, Home Depo, Hardware store, Farm store,
Old Jan 19, 2010 | 05:52 PM
DuallyMike's Avatar
DuallyMike
Can also check Summit racing.com
Old Jan 19, 2010 | 06:13 PM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
10,000lb "KEEPERS" were at Lowes & Home Depot for $10, a while back. Always keep a backup unit onboard just in case a strap is damaged while in use.
Old Jan 20, 2010 | 08:10 AM
dkf's Avatar
dkf
Buying the cheapest straps around is a bad idea IMO. I don't depend on junk straps from Asia to keep my stuff on my trailer.
Old Jan 20, 2010 | 09:50 AM
BillyBob69's Avatar
BillyBob69
Check some local Farm Supply stores...Like Tractor Supply, Big R, Murdocks... etc. I get mine from Big R here locally and they are $20 for the 20,000lb 30ft straps. Big? Yes...But they work great since I usually pull them out for hauling a tractor or hay.
They usually carry other sizes too depending on what you are going to use them for.
