wireing diagram
Old Nov 27, 1999 | 07:43 PM
Chad Burns
Guest
Posts: n/a
wireing diagram
Can anyone tell me where I might find a wireing diagram for a '70 F100? Preferably online? Or can someone scan one in and send it to me? We had a steering shaft grab a wire and it ended up yanking everything from the cab to the tailgate! Boy we're having fun now! NOT! Thanks in advance. BTW, my e-mail is chadb@sprintmail.com
Old Nov 28, 1999 | 09:09 AM
StockMan's Avatar
StockMan
wireing diagram
I'm not aware of any wiring diagram available online. The original harness is color coded. All you need to do is follow that "diagram". If your wires are "ripped beyond recognition" you would be way ahead going to a yard and finding a decent wiring harness from front to rear. You can uncouple the harness under the dash and pass it through the firewall. No cutting or splicing involved. Choose your new "used" harness wisely. You don't want to buy into new problems.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Nov 28, 1999 | 09:15 AM
Trail_Rider's Avatar
Trail_Rider
wireing diagram
Good reply stockman......that's about the only way there is to do it that I'd know of
Trail Rider
Old Nov 28, 1999 | 09:24 AM
StockMan's Avatar
StockMan
wireing diagram
Thanks Trail Rider....I would add for you Chad that I have the wiring diagram book for 1967's. It is probably the same diagram for the rear harness on your truck. The diagram is good for trouble shooting problems with harnesses that are intact because it shows you the path and color sequence for all the circuits. I think you would be disappointed though because it really won't help you fix the problem you have. I stand by my first response as your best option.
Stock Man
Old Nov 28, 1999 | 01:24 PM
Chad Burns
Guest
Posts: n/a
wireing diagram
Well, thanks for the quick responses. I guess we will just have to go for it and hope we can get it all back together. Unfortunately, a new harness is not in the equation for a bit. He has pretty much overspent his budget getting the truck this far. Thanks again
Old Nov 28, 1999 | 11:25 PM
mk's Avatar
mk
wireing diagram
Chad, check with your local auto/electric shops. I've had good luck getting them to photocopy a page or two for me. Once I even found a complete set of diagrams in a book at a radiator/mechanical shop. good luck mike
Old Nov 29, 1999 | 06:15 PM
John Boggs's Avatar
John Boggs
wireing diagram
I the shop manuals for that truck, I'll see if it has one and e-mail you back later. You might post a fax number just in case I can get you one.
Old Nov 30, 1999 | 12:50 AM
Justin Weber
Guest
Posts: n/a
wireing diagram
JordanL91
16
Mar 13, 2015 10:23 AM
Rudiak
Mar 31, 2012 03:29 PM
jodyhutch
Electrical Systems/Wiring
Feb 17, 2004 03:39 PM
birdchaser1
Feb 22, 2002 06:14 PM
