Fire inside brake drum !
Old 12-02-1999, 10:04 PM
Corey Berkman
Guest
Posts: n/a
Old 12-03-1999, 01:19 AM
Nod's Avatar
Nod
Nod is offline
My friend,s 9 inch rear end caught on fire behind the brake drum , it burned so hot he could not put it out with a fire extinguisher.My question is, can you reuse the axle after it gets real hot? He said it was so hot it melted the backing plate and all brake parts.All opinions are appreciated!
Old 12-03-1999, 06:31 AM
jowilker's Avatar
jowilker
jowilker is offline
Nod, even if the axle is OK, He will have to pull it, to replace bearings, seals and other parts, and those are cheap enough to replace. I suggest DO IT. He should be able to but a whole rear set up for less than $200.00
IMHO
John
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Fire inside brake drum !
