oil pressure
Old Jan 18, 2010 | 02:26 PM
bigangel's Avatar
bigangel
oil pressure
hi,i have a ford e 150 1989,4.9 lit 6 cilinders.when the van is cold i have pressure in the midle (50%),but when the van its hot like a 1 hour drive and i stop.the pressure drop like dead.no pressure sings, but when i run againg clime like 1/4. i want to know where is the oil pressure sender to change it.or is there other problems with the van.thanks
Old Jan 18, 2010 | 03:53 PM
60sedandelivery's Avatar
60sedandelivery
low or no oil pressure
i had the same problem with my 86 and it needed new crankshaft bearings...they just wear and there is so much space that it cant build up oil pressure when the oil is hot ...when the oil gets hot it turns very thin ...and that was that......
Old Jan 18, 2010 | 06:39 PM
jimbbski's Avatar
jimbbski
What he said. I had a Cheby with a 454 that had this problem and once I replaced the rod bearings, the mains were OK, the oil pressure came up to normal. I replaced the oil pump with a new one at the same time.
Old Jan 19, 2010 | 10:03 AM
bigangel's Avatar
bigangel
Unhappy oil pressure problems
thanks for everything!
1. I need the location of the oil sender unit, so i can change it?
2. Should I clean the oil pan to get more pressure (if it safe to do it)?
3. Should I use 20w50 oil instead of 10w40 or change to synthetic oil?
4. If its safe to change the oil filter to a smaller one?
5. Can you give me the procedure for changing the oil pan.
Thanks.
Old Jan 19, 2010 | 10:28 AM
jimbbski's Avatar
jimbbski
Look on the block just above the oil filter, that's where it wan on my 302.
What do you mean "Clean the oil pan?" That won't help your problem.
Not worth using synthetic one an old engine, but a 15W-40 or a 20W-50 may help, but it's only a stop gap measure. The oil pan will have to come off if the pressure does not come up and the bearings replaced.
Yes, but why?
Thanks.
Find a repair manual for your vehicle, I've found some at my local library if you can't find one for sale of don't want to buy one.
Old Jan 19, 2010 | 05:29 PM
bigangel's Avatar
bigangel
oil pressure
I really appreciate your time to explain me. thanks for everything
