Suspension too stiff? Or?
Old Jan 18, 2010 | 01:07 PM
Philbil's Avatar
Philbil
I have replaced the front spring on my 2005 v-10 4x4 with the v code springs (maybe the wrong ones?). Have installed the RAS on the rear to keep the tail from sagging and have Rancho 9000s and a Rancho 5000 steering stabilizer.
Have also lowered the front pressure to 45lb and rear to 55 on the BFG tires. The front sway bar links have been replaced.
My truck now bounces up and down after hitting even minor bumps. I have set the shocks on every setting, and can make a small improvement before I get to no shock absorbsion at all, at which time the bouncing is almost non-existent.
I have had the front end checked out and the mechanic says everything is fine. I am now going to get the tires re-balanced.
Aside from alignment, is it possible the springs in front are too stiff? Or is this conglomeration of parts incorrect?
Sorry for the length of the message here. Any help is appreciated
ExPACamper
Mar 30, 2016 01:05 PM
Rifboy
2009 - 2014 F150
May 9, 2014 07:48 PM
ecam8000
Jan 7, 2012 02:28 PM
big red 73
Oct 7, 2010 01:20 PM
surveyguy
Aug 12, 2009 10:51 PM
